-   -   Bad water taste (http://www.diychatroom.com/f2/bad-water-taste-17728/)
dubby 02-26-2008 11:43 PM
Bad water taste
To start I don't know where to post this, so please forgive me if this is in the wrong area.
Our water in this area is horrible and barely drinkable. Since I can remember it's been this bad. I live in South Africa, and English is not my first language, so I'm not 100% sure what the English word for it is, but a great example of what is wrong with out water (apart from it tasting like crap) is that when I boil the kettle it forms a white layer inside. It forms a noticable white layer even after the first boil of a new kettle. If I use one of those "Clean your kettle" solutions, it works like a charm, but then as soon as I boil the kettle again its back and gets progressively worse each time I boil it. I don't have a lot of money to spend on top of the range filter systems, so I bought a tap filter, hoping that it would help somewhat. It hardly helps. When I pour the water into my cup of coffee after boiling it I get white floaty bits in my cup...
If anyone has any idea what this is called, please let me know and also if anyone has any ideas on how to rectify this without having to spend $100's please let me know. I'm getting quite sick of having white floaty bits in my :censored: expensive coffee.
Dave
wire_twister 02-27-2008 06:30 AM
Dave, I know nothing about the water in South Africa, but the white stuff you describe in the kettle sounds like either lime or calcium. As to what to do about it, buy bottled water. I do not know of an inexpensive filter that will remove these things from your water. Does the tap filter you bought do any good? You might try a cartridge filter on incoming water line with activated charcoal in it, but I dont know if it will help.
End Grain 02-27-2008 09:00 AM
Dubby, there are several inexpensive simple in-line water filters that will specifically remove calcium and lime, chlorine and odor, or sediment, minerals, etc. You might want to look on-line at ACE Hardware's site to see a few examples. www.acehardware.com. They range from straight in-line where plastic tubing is interrupted to more permanent housings with replaceable filter cartridges. Here in Arizona, calcium, lime, chlorine and odor are a continual nuisance and many of the filters I've recommended have solved the problem for customer's drinking water without the need to buy and install a reverse osmosis system or water softener system.
Leah Frances 02-28-2008 09:08 AM
Your local water utility should provide at least an annual water quality report. Mine is available online. It won't fix the problem, but it might give you some information that would be interesting.
dubby 02-28-2008 02:02 PM
mmm, in our dreams here in South Africa! Not a chance in ..uhm... that very warm place ... they'll ever produce a water quality report, let alone a yearly report. The advice you gave about what it could be sounds about right, sounds familiar. I'm busy surfing AceHardware.com to see if I can find out anything that could help me. Bottled water might be the way, but wow that might just work out more expensive! Just out of curiousity, should a water softener fix something like this? I definitely cannot afford putting one of those in, but just curious.
Any other advice or tips would GREATLY be appreciated. Thanks for the advice so far, hopefully an inline filter will do the trick...
OH! This is the filter I have: http://www.acehardware.com/product/i...entPage=family
It doesn't really do MUCH for the lime/calcium bits. Activated carbon, this is a dumb question, but it would say whether it uses active carbon if it does right?
d
Kingfisher 02-28-2008 04:56 PM
this should fix it
http://www.lowes.com/lowes/lkn?actio...R25&lpage=none
Ron6519 02-28-2008 06:09 PM
It sounds like you need a water conditioning system, not a filter. These minerals are in solution, so they are probably not filterable. One of my customers in upstate, NY who is on well water, has a Culligan system to condition the water as it enters the house.
Ron
End Grain 02-28-2008 07:59 PM
Dubby, here's one at ACE. There are many such in-line filters out there that you can install quickly and at very little cost. This particular one is good for 4,000 gallons.
http://www.acehardware.com/product/i...ductId=1275795
Leah Frances 02-29-2008 02:48 PM
Dubby - one last comment (from me at least) - I dislike the taste of softened water. Many people love it. Find out if any of your friends or neighbors have a system and taste it. You don't want to pay for a system and still not like how your water tastes.
I grew up with highly chlorinated water so when I moved to an area with no chlorination I thought the water tasted bad. My Grandmother has really sulfury water, she thinks water that doesn't smell like rotten eggs tastes bad.
I guess you like what you like.
dubby 03-03-2008 11:17 PM
Thank you
Thank you! :D
I'm gonna try and look for that Culligan filter here in SA, if I can't find it, at least I know where to start. I can maybe order online from ACE. Thanks alot :D Really appreciate everyone's help.
