Bad Ceiling Cracks In Entire House - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-08-2012, 12:40 AM   #1
Bad Ceiling Cracks in Entire House
I have a florida home i purchased recenently. It is a block home with a flat roof. the entire house has major ceiling cracks. All the cracks appear to be at the perimeter of the sheet rock joints. I removed a small interior wall and noticed termite damage in the rafter. Im not for sure what my next step should be, please help!
john0kirk is offline   Reply With Quote
Old 02-08-2012, 01:13 AM   #2
Rewards Points: 12,848
Looks like you got taken.
Guess you did not get a home or termite inspection before buying? Big mistake.
Unless someone pulls the sheetrock down no way to really tell with a flat roofed house.
Old 02-08-2012, 05:18 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 880
What will ultimately need to happen will be determined by the extent of the termite infiltration.
You are going to need to do some exploration and it is probably time to call in a pro so you can help avoid costly oversights and errors.
Old 02-09-2012, 07:06 AM   #4
PoleCat's Avatar
Rewards Points: 1,646
Every joint in the whole house has failed? I would suspect improper installation. I would pull it all down one room at a time and make sure I found the problem(s). You are going to need access anyway to repair any significant termite damage that may exist.
PoleCat is offline   Reply With Quote
What's the best way to paint the entire interior of our house? Shpigford Painting 21 07-17-2011 06:51 PM
Help with ceiling cracks danar40 Drywall & Plaster 1 01-25-2010 01:19 AM
repairing drywall cracks in ceiling justin 418 Drywall & Plaster 3 12-28-2009 06:18 PM
Grounding an Entire House dglockster Electrical 11 04-17-2008 10:29 AM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 09:23 PM
