Bad Batch? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-22-2009, 02:11 PM   #1
Rewards Points: 154
Bad Batch?
The photo shows rusted nail heads on some siding that I installed last year. That portion of the house is moderately exposed to rain. The nails are supposed to be hot dip galvanized. Could this be a bad batch? A friend told me hand driven nails are better coated and less likely to lift out of the wood. Is this true?
ovahimba is offline   Reply With Quote
Old 11-22-2009, 02:48 PM   #2
the Musigician
DangerMouse's Avatar
i see the problem. griprite nails. made in (guess where?)
DM
Old 11-22-2009, 04:00 PM   #3
Remodeling Contractor
yes.. these are cheap nails. Water triggers the corrosive action on the nail. The galvanizing deters this but eats the coating away over time. The cheaper nails have much less of a coating so fail much quicker. For longer lasting work use stainless steel nails.
Old 11-22-2009, 09:11 PM   #4
Rewards Points: 154
Thanks for the responses. I didn't realize they were cheap nails and the consequences. I'll be thinking about the small amount I saved not buying higher quality as I pull them out one by one.
Old 11-23-2009, 06:02 AM   #5
the Musigician
Maze Stormguard nails (made in Illinois, USA)
is what I use. they don't bend in half either.
DM
Old 11-23-2009, 07:02 AM   #6
Rewards Points: 264
What DangerMouse said. Maze is good stuff, and they have varieties for many materials and applications. Lowes used to stock them here, not sure who carries them now.
Check their web site, last time I looked they had some good faq there.
7echo is offline   Reply With Quote
defective joint compound newbpainter General DIY Discussions 8 05-24-2009 10:52 AM
Konecto Problems Please Help jennydavis Flooring 39 12-29-2008 11:41 PM
Konecto Sierra Jackson Plank Flooring jennydavis Flooring 9 09-17-2008 06:59 PM
Solar hot water + tankless gp_wa Plumbing 3 08-27-2008 01:48 PM
Batch Codes On GAF Docfletcher Roofing/Siding 26 08-26-2007 11:17 PM
