Backflow Valve Repair - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 05-07-2011, 07:22 AM   #1
backflow valve repair
I had a back flow valve freeze and crack this past winter. it also blew out the seat and spring. can this be repaired? If so, how difficult?
NormanDIY is offline   Reply With Quote
Old 05-07-2011, 08:00 AM   #2
Experienced
Jackofall1's Avatar
Hello and welcome Norman, to the best DIY'r site on the web.
Repair of a frozen valve is not possible, there is a good change that the pressure of the ice has deformed the valve, replace it, and next winter ensure it is drained completely so as not to cause the issue again.
Mark
Old 05-07-2011, 09:10 AM   #3
Jack - Thanks for the response. Instructions indicate after initial installation a discharge from the relief valve may occur due to inadequate initial flushing. how long should this discharge last? is there an adjustment? It says clean check valve if flushing doesn't clear. how is that done?
Old 05-08-2011, 06:06 AM   #4
Rewards Points: 5,336
If it's cracked, replace it.
Ron
Old 05-10-2011, 11:10 AM   #5
Household Handyman
Rewards Points: 1,408
If this is a true Back Flow Prevention (BPD) device, and not a check valve, then local and/or Federal codes will dictate that it must be replaced if damaged at all. BPD's must be able to pass an annual/periodic inspection and one that has been cracked and repaired most likely will not pass the visual nor the dynamic testing.
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 04:19 PM
Dual Check Valve Backflow Preventer HairClog Plumbing 13 08-18-2010 07:56 AM
How to install thermostatic reactive valve and repack supply valve Leah Frances How To Guides 1 06-10-2009 10:49 AM
Resource for understanding gas valve? darsunt HVAC 19 02-03-2009 11:08 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 11:16 AM
