Backfill Concerns - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-22-2008, 02:07 AM   #1
backfill concerns
I had a pool tied in to my house weepers for drainage around the pool without knowing and it is overloading my sump pump (They probably didn't know I had a sump pump). They are agreeing to fix the problem but I had some concerns. In the process of attaching they scrapped about a 4-5 foot wide (width of machine cup) on wall to get down to the weeper around the house. They tied into the weeper and layed about a 1-2 feet of clay back against the foundation area(probably just the clay they remove to make path from pool to wall). They are ripping out the concrete and I want to make sure they fix the problem correctly.
To stop the flow into the weeper should they just pull cut the attached weeper and cap the T that comes through the clay barrier - don't want them to shove something in and block flow of water around house to sump pump?
I told them they should remove all stone in the pit they created where water would collect to go in weeper and replace it with dirt which will come level to the other existing sides - is this a good idea
Should I be concerned about the 4' wide clay barrier against the house and any pressure it may cause against foundation wall (should any moisture in clay eventually settle to weeper below?)?
morta is offline   Reply With Quote
Old 11-22-2008, 08:06 AM   #2
joed's Avatar
Rewards Points: 12,458
You biggest concern should be what are they going to do with the water from around the pool? How are they going to get rid if it?
Old 11-22-2008, 09:05 AM   #3
with removal of concrete they will have access to put in sump barrel in overdig which will have a sump pump wired to my shed. The water can then be redirected away form yard.
Old 11-22-2008, 10:38 AM   #4
joed's Avatar
Wouldn't be a lot easier to just put in a bigger sump pump in the basment?
Old 11-22-2008, 12:12 PM   #5
put in largest I could find and also put in battery backup pump - pump ran steady for full day and battery backup pump could not keep up with water when tested - shouldn't have to feel uneasy about possible flood during storms if pump breaks down due to overuse and battery backup can't handle the job
Old 11-22-2008, 07:17 PM   #6
joed's Avatar
OK. You seem to know what you need. Just trying to understand why an easier solution wasn't being used.
Backfill for garage sadkins Building & Construction 5 10-03-2008 04:22 AM
Concerns On Hardiplank Install ptra Building & Construction 2 04-23-2008 05:51 PM
backfill ? joshm Landscaping & Lawn Care 13 04-23-2008 12:07 PM
backfill question. joshm General DIY Discussions 4 03-25-2008 04:46 PM
Survey Results - Cavity Wall Insulation - Health Concerns mchu6am4 Building & Construction 5 03-14-2007 02:50 PM
