Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 02-11-2007, 09:51 AM   #1
backerboard
i recently installed backerboard around my new tub.my question is im installing 16 inch tile on it.the tile man told me it would be ok to go ahead and texture and paint .i told him since i dont know exactly were the tile will end that i would get texture on the backerboard since the tile will not go all the way to the ceiling.he said not to worry that he would add more adhesive to the thin set.is this suitable to do or not?
glassman is offline   Reply With Quote
Old 02-11-2007, 10:33 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
backerboard
That is fine. There is a common misconception that you can't tile over drywall, when you can.
The whole issue of 'backer board' (Cement board) is that, it should be used in areas where there is direct water or high moisture. The top area of your shower (above the curtain or glass doors) will be fine with tile placed over your texture. Texture is comprised of the same material as wallboard. As stated, you can tile onto wallboard. It is done all the time in public bathrooms walls and private bathroom walls that don't get direct water/moisture.
- Build Well -
Installing backerboard - replace particle board? salvop Flooring 10 04-29-2011 11:32 PM
Backerboard not in mortar -- How bad is that? House_Amuck Flooring 28 09-27-2010 11:33 PM
Concrete backerboard vs. Greenboard amakarevic Building & Construction 1 05-22-2007 06:54 AM
backerboard glassman Remodeling 1 02-06-2007 09:36 PM
What Comes First-Drywall or Backerboard?? allen1466 Remodeling 15 04-01-2006 10:57 AM
