-   -   backerboard (http://www.diychatroom.com/f2/backerboard-6434/)
glassman 02-11-2007 09:51 AM
backerboard
i recently installed backerboard around my new tub.my question is im installing 16 inch tile on it.the tile man told me it would be ok to go ahead and texture and paint .i told him since i dont know exactly were the tile will end that i would get texture on the backerboard since the tile will not go all the way to the ceiling.he said not to worry that he would add more adhesive to the thin set.is this suitable to do or not?
AtlanticWBConst. 02-11-2007 10:33 AM
That is fine. There is a common misconception that you can't tile over drywall, when you can.
The whole issue of 'backer board' (Cement board) is that, it should be used in areas where there is direct water or high moisture. The top area of your shower (above the curtain or glass doors) will be fine with tile placed over your texture. Texture is comprised of the same material as wallboard. As stated, you can tile onto wallboard. It is done all the time in public bathrooms walls and private bathroom walls that don't get direct water/moisture.
