AZEK/PROCELL Decking - General DIY Discussions - Page 3 - DIY Chatroom Home Improvement Forum
Old 05-03-2012, 06:16 PM   #31
robertcdf's Avatar
Originally Posted by Centenco View Post
Spring of 2012 Still a problem. Over 700 square foot deck, sent pictures to Azek and now I need to pursue Cortex fasteners is what I am told. Some are coming back up and contractor would not even put the rest in as he feels the problem will continue. We have done decks on three other homes since 2010, none have had the problems I have had. Some discoloration, but mostly tripping hazard. bowing and excessive movement due to expansion and contraction.
Where in Colorado are you? I've always told people to stay away from PVC products in Colorado UNLESS it's a smaller deck like a 20' wide deck with no seams and the decking can overhang the framing.
robertcdf is offline   Reply With Quote
Old 07-13-2012, 10:37 AM   #32
Same problem. I have not contacted the company and have tried everything without results. Have you had any additional contact?
Needles is offline   Reply With Quote
Old 09-25-2012, 08:28 PM   #33
Just built an Azek deck and so far no staining. My problem is with water pooling. The deck is pitched so as to drain water to gaps across the boards. The boards are "dished", not crowned so water pools on the boards and I need to sweep it off every time it rains. I am concerned about the winter months! Has anyone experienced this with AZEK decks???
robertflaherty3 is offline   Reply With Quote
Old 10-16-2012, 11:50 AM   #34
Same issues with our deck. Location: New Jersey. Promised to be "no maintenance". Severe oxidation, staining. Has anyone gotten any relief from AZEK? Has anyone engaged attorneys?
halfast is offline   Reply With Quote
Old 12-03-2012, 06:00 PM   #35
Azek Lawsuit
Seeger Weiss LLP has extensive experience representing consumers across the country. We are currently investigating claims for a class action suit against Azek for defective decking and trim boards. If you or someone you know has defective Azek product, please contact us at www.seegerweiss.com free of charge to discuss your situation.
sashalevin is offline   Reply With Quote
Old 09-06-2013, 12:46 PM   #36
Angry
Azek decking the worst
Just got off phone with azek customer service...the person actually told me I should have researched the product better online so I would know what the problems other customers were complaining about and maybe I wouldn't have purchased it. They also like to push their problems on other companies. Cortex screws pulling out..not our problem call cortex. Won't guarantee deckmax conditioner they recommend...not their problem call deckmax...when is azek going to take responsibility. Just contacted the firm handling class action suit. So tired of being screwed by this company.
Dfrancis is offline   Reply With Quote
Old 10-03-2013, 08:08 PM   #37
Connecticut
My azek deck has faded wherever the sun has hit it. We have a two level deck and the upper level rarely gets sun. The lower level gets full sun. It has definetly faded. There are also scratch marks from chairs. No sunscreen, bug spray, or anything else.
Mikect2000 is offline   Reply With Quote
Old 08-20-2015, 09:57 AM   #38
Rewards Points: 2
After years of looking at this problem I found a cheep and effective solution. Wipe it down with Goof-off.
It restored the look to new. I couldn't believe it. It didn't harm the surface and in fact, cleaned it at the same time. I used to have a line across my deck where the sun did and didn't hit. It's gone, now.
Forget law suits and expensive cleaners. Just be careful and cover up because goofoff can cause a skin rash.
nydja is offline   Reply With Quote
Old 06-13-2017, 05:25 PM   #39
Rewards Points: 4
Re: AZEK/PROCELL Decking
As was suggested by a previous reviewer, I used "Goof Off " stain remover on the stains on my deck and it actually removed the stains that I could not remove with anything I tried including bleach. I saturated paper towels with the stain remover and rubbed out the stain followed by hosing down with water. Soap with water would probably be a better idea.
However, I found that the deck color was transferred to the paper towel with the stain. Since the color of the decking is through the entire board, I assume there is nothing to be concerned with. I examined the surface I just treated and I saw no deterioration after using this product.
Thank you for the suggestion.
Phil K is offline   Reply With Quote
Old 06-14-2017, 11:34 AM   #40
Rewards Points: 4
I must retract my review of the use of Goof-Off that I posted yesterday. The following morning after my deck dried after using this product, although it removed the original stain, it added a stain of its own which is worse than the original stain so do not try it.
Trex decking LL1 General DIY Discussions 56 09-30-2011 09:55 PM
Trex Decking over Treated Decking retired2pa General DIY Discussions 6 12-15-2009 06:16 PM
2x6 Roof Decking Over Patio bjansen Roofing/Siding 4 06-17-2009 09:34 AM
installing plywood or backer board over decking gwags Building & Construction 6 04-02-2009 04:55 AM
Decking Michael Avram Building & Construction 2 05-26-2008 07:24 PM
