Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 07-08-2006, 11:33 AM   #1
attic/wall insulation question
All,
I have some questions about insulation if anyone would be gracious enough to offer some assistance. Just a little background, I will be assiting with the new contruction of my home, which is in Alabama. We have mild winters and hot summers and it is usually very humid most of the year. I hope to do mych of the insulating and wanted to know how the vapor barrier needed to be installed? In the walls, I will probably be using an r-13. Will the paper side need to face toward the inside of the house? Also, in the attic (I will be blowing in the recycled newpaper/phonebook insulation), is it best to install some type of plastic sheeting under the ceiling joist before the sheetrock below is installed? it a vapor barrier even needed?
Thanks,
Jason
jasonr26 is offline   Reply With Quote
Old 07-08-2006, 11:47 AM   #2
The paper side (vapor barrier) of the insulation needs to face the "heated" space.
It would save time to install the vapor barrier before the drywall is installed for the attic.
redline is offline   Reply With Quote
Old 07-11-2006, 07:59 AM   #3
According to Energy Codes, warm, humid locations like Alabama require no vapor retarders in walls or ceilings, or when they are used, will be placed on the unheated side of wall and ceiling assemblies.
Vented attics also require no vapor retarders.
Vapor retarders are also usually not required when using blown cellulose. Check your manufacturer's installation instructions.
For the right answer for your location, contact your building code officials.
manhattan42 is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Insulation question Outbacker HVAC 16 12-29-2008 10:54 PM
Insulation question hswaters General Discussion 9 12-28-2008 09:18 PM
Rigid insulation question Endeavor General Discussion 2 07-17-2007 11:27 AM
yet another insulation question bobbyhill Building & Construction 2 12-06-2006 01:01 PM
