Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 04-17-2008, 12:47 AM   #1
Attic venting
I have a new roof with a ridge vent. I also have two gable vents (powered). They were mounted to force the air out of the attic. My question is does this defeat the idea of the ridge vent. Should these both be drawing air in from outside. In addition, I also have a whole house fan.
sblag
sblag is offline   Reply With Quote
Old 04-18-2008, 11:52 PM   #2
Attic venting
Do you have soffit vents to go along with the ridge vent? Where is the whole house fan mounted? It works better directly exhausted to the outside with a shutter installed in the ceiling of the second floor.
You have a very odd setup. It's like they couldn't figure what to put in, so they put in everything.
Ron
Old 04-23-2008, 11:17 PM   #3
remodeling pro
Attic venting
Ridge vents are best used in conjucton with soffit level entry of fresh air. Combining ridge and gable vents have been shown to create dead areas of air in the attic. I don't recall the sites, but if you search around for attic ventilation, you will come across a few articles about the effectiveness ,or lack thereof, of venting combinations.
troubleseeker is offline   Reply With Quote
Old 05-01-2008, 04:32 PM   #4
Building codes guy, Mod
thekctermite's Avatar
Attic venting
The whole idea is CROSS-VENTILATING the attic. Soffit vents in combination with ridge vents, turbines, conventional roof vents, or powered vents are all beneficial. More ventilation is a good thing.
If you don't have soffit vents, you're not cross-ventilating the attic.
thekctermite is offline   Reply With Quote
More On This Topic
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are doing a frame walk and insulation inspection on this home. In talking about insulation, one area that we need to cover is how well your house is sealed... Read More »
How to Frame the Roof Ridge
How to Frame the Roof Ridge by Expert Village
Hi, I'm Tom Shean and today on behalf of Expert Village I'm going to show you how to install a metal roof. Where the ridge is to be ventilated and the coursing is less than a full tile, a one inch board is laid parallel with the ridge on each side... Read More »
How to Pressurize a Room
How to Pressurize a Room by Expert Village
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are going to do a duct test in this house. Okay right up here above you we have taped off the air conditioning vent into this room. So I want you to think... Read More »
I’m going to demonstrate some of the snake styling of black dragon kung fu system. First, we’re going to demonstrate the triple form. Firm stance is used with both feet facing primarily forward. You’ll be able to move in and out quickly... Read More »
Repair corroded lines and in your car air conditioner when repairing the accumulator; learn how in this free DIY auto-mechanic video from our expert in automotive AC repair and maintenance. Read More »
Attic Smell from A/C - I'm at wit's end! cidsamuth HVAC 17 09-06-2008 01:59 PM
Bird Block Soffit replacement options? Heather WA Roofing 3 05-06-2007 06:58 PM
Attic Fan Venting joedadog Building & Construction 2 02-02-2007 07:05 AM
Attic Venting Jerry8C Roofing 9 03-18-2006 01:28 PM
Attic Conversion and Venting jjmanes Remodeling 4 11-09-2005 02:51 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
