Attic Project - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-21-2009, 08:00 PM   #1
Attic project
I plan on making the attic into a living space. Is it necessary to replace attic insulation?
mlamartina is offline   Reply With Quote
Old 09-21-2009, 08:02 PM   #2
Replace what insulation?
In the floor, rafters?
What R value is installed?
Where are you located?
Old 09-21-2009, 08:05 PM   #3
There is about 6 inches of insulation in the rafters. I don't know the R rating. I do know that it was put in about 25 years ago.
Old 09-21-2009, 09:34 PM   #4
Registered User
Rewards Points: 526
That would be the least of my worries. You need: legal access stairway; proper sized floor joists; proper thickness rafters for required insulation; new lighting circuit; new heating there; required egress if a bedroom; required light and ventilation (window); required headroom; a permit from the local Building Department to ensure it all doesn't just fall down.
Be safe, Gary
Old 09-21-2009, 09:49 PM   #5
6" of fiberglass? That is only R19 usually
Where are you located? That decides how much is required
I have R38 in most of my ceiling
Old 09-22-2009, 01:10 AM   #6
R19 would be consistent to areas like Florida or Texas.
Sonja28 is offline   Reply With Quote
Old 09-22-2009, 06:08 AM   #7
attic
Thanks Gary-yes we have all of that. I just thought the insulation was dirty looking. I quess since the ceiling will cover it I don't have to worry. I am in Baltimore.
Old 09-22-2009, 07:17 AM   #8
With only R19 up there your heating costs will be higher
When getting a building permit here we are required to have an "energy audit" performed on the insulation that will be used
You may not pass that audit if required
Old 09-22-2009, 01:24 PM   #9
Registered User
Rewards Points: 526
Dirty looking --- if glass batt- just on the top, from dirt and dust, or inside it from air leaks in the ceiling below. A sure sign you need to plug all holes with fire-stopping foam- around pipes, light fixture boxes, wires holes, chimney, bath fan, etc. to keep the conditioned air in the house, not the attic-leading to ice dams and mold. Make sure to be 3" away from can lights not rated IC. (insulation cover)
Be safe, Gary
Old 09-22-2009, 07:16 PM   #10
Having an energy audit is a good idea. We decided the contractor will replace the insulation.
Thanks so much
Raccoons in the attic electricpete Pest Control 17 05-12-2011 04:02 AM
Recently Topped Up Attic with Blown Insulation...Now I have Frost/Condensation earthad1 Building & Construction 81 02-18-2011 12:42 PM
Finished attic humidity? kcrossley2 HVAC 2 08-11-2009 05:06 AM
how hard could it be to add extra attic insulation? diy'er on LI Building & Construction 15 07-19-2009 07:07 AM
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 02:28 PM
