Attic Ladder Placement ? - General DIY Discussions - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-21-2012, 09:11 AM   #16
Rewards Points: 240
Originally Posted by rjniles View Post
The framing for your ladder looks fine but I would worry about the rest of the ceiling framing, it looks like 2by4 on pretty wide centers. I would beef it all up before putting much weigh (or your own body) on it.
Also, is that "knob & tube" wiring still live? If it is you are overdue for some re-wiring.
indeed. i am going to add more lumber, and then 1/2 osb for a landing.
like i said, no way would i put anything on that original framing.
yes & yes, well, it was . but i think the wires going up to the front, are were the original service entered the building. though i could be wrong.
and, while the K&T does look to be in good condition. 1 of the reasons for the ladder is to aid in rewiring.
Fix'n it is offline   Reply With Quote
Old 04-21-2012, 12:31 PM   #17
AHH, SPANS!!!
Rewards Points: 1,166
for the finished look you could add some facade lumber onto the plywood of the door that matches the existing ceiling boards. then trim out around the door with a thicker trim - 5/4 maybe, and this will help hide the fact that the added facade sticks down further than original ceiling boards.
if you consider doing this, be sure to line up the newly installed boards' grooves with the original ceiling boards' grooves so that line of sight is not off
hand drive is offline   Reply With Quote
Old 04-22-2012, 09:22 AM   #18
Rewards Points: 240
thanx HD. i am not worried about it right now. i come across free stuff now&then. so i will wait till some nice free wood comes along, and put that up there.
here are the almost finished pics. i could not get the 4x 7 1/2' sheet up there. so i had to cut it in half.
last pic is of the catwalk, that is going to be modified somehow.
btw, i am going up there today, to expose the K&T to see what i am working with. and how i am going to run the new wiring.
attic ladder placement ?-img_1750.jpg   attic ladder placement ?-img_1752.jpg   attic ladder placement ?-img_1756.jpg
Telescoping attic ladder rjniles General DIY Discussions 6 04-05-2012 08:06 PM
Attic project - Would like opinions whataboutj Insulation 6 06-29-2011 03:07 PM
Attic Ventilation Question handy man88 Roofing/Siding 10 02-12-2010 10:50 PM
Attic moisture Carstonio Roofing/Siding 14 01-29-2009 11:35 AM
Attic Ladder suggestions jdp72 Carpentry 5 11-15-2006 07:06 AM
