Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 06-19-2008, 07:37 PM   #1
Attic fans??
I live in the wonderful desert of Southwestern Arizona. The winters are awesome but the summers a miserably HOT!! I've heard people talk about installing attic fans in their houses before to ventilate the attic with the intention of keeping the attic cooler thus keeping the house cooler and saving on energy costs...I'm wondering if anyone can tell me if these work and are worth the effort and expence?
If so...How are they installed?
Any info will be greatly appreciated,
Thanks,
JB
CptSD is offline   Reply With Quote
Old 06-19-2008, 08:33 PM   #2
Attic fans??
I also live in southern AZ. I just got through investigating this myself.
The first thing you need to do is to see if you actually have a problem or not. That is, compare the temperature of your attic to the outside temp. My home was built in 1999, and quite frankly the attic stays reasonably cool without any fan at all. The attic only runs about 10 degrees hotter than the outside temp, which I think is about as good as you can expect. This can mean that your attic is 110 degrees, but if it is 100 outside you can't expect much improvement. (I suppose if you have an a/c unit in the attic that could have some 'waste' cooling effect as well. I looked at the attic temp when the a/c hadn't run for quite a few hours.)
I have a tile roof, with soffet vents along the entire side of the house, plus a gable vent on one end only. This seems to be plenty.
Some people report that their attics are 30 or more degrees hotter than the outside temp, which probably does indicate a problem.
From what I have read, using sufficient passive vents is a better idea than smaller forced air venting.
pweller is offline   Reply With Quote
Old 06-19-2008, 09:35 PM   #3
Attic fans??
Thanks for the reply...Our house is a new two story with a tile roof. I don't realy know too much about how it is vented but I will have to do some research.
Thanks again,
JB
Attic Smell from A/C - I'm at wit's end! cidsamuth HVAC 17 09-06-2008 01:59 PM
Attic venting - Ridge vents or fans? jebmke Roofing/Siding 16 07-03-2008 12:03 PM
Powered Attic Fan question spup345 Roofing/Siding 9 06-30-2008 09:10 PM
Multiple bathroom exhaust fans dpreznik HVAC 17 08-30-2007 01:09 PM
Attic In & Out Fans nedjinski HVAC 1 04-20-2006 04:31 PM
