Attic Fan Without Climbing On Roof? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-28-2008, 07:49 AM   #1
Attic fan without climbing on roof?
I would like to add a roof-mounted attic fan. I am quite handy (carpentry, electrical, plumbing, you name it), however I am terrified of heights. Is there any way to install an attic fan without having to climb on the roof? Does someone make a model that allows everything to be done through the hole cut in the roof?
Thanks in advance for any help!
P.S. - my house does not have gable vents, otherwise that would be the simple answer......
sketh24 is offline   Reply With Quote
Old 05-01-2008, 03:28 PM   #2
Registered User
Termite's Avatar
I hear you about not liking heights.
I see no possible way that you could install a fan in the roof without working ON the roof. Flashing, shingles, and general attachment would take place on the roof itself.
Are you trying to ventilate the attic itself or are you wanting an attic fan to pull outdoor air through the living areas of the house? If you penetrate the roof, plan on climbing up on it. You can install a whole-house attic fan without going any higher than the attic, but it won't ventilate the attic.
Gambrel Attic Roof Truss ETD66SS Carpentry 28 05-11-2009 02:36 PM
is an attic vent required for cedar shingle roof? walenta Building & Construction 2 10-25-2007 10:31 AM
rust on nails in attic on one side of roof only this old house Roofing/Siding 3 01-27-2007 09:56 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 06:17 AM
Framing Attic Walls but Roof Has SAG! luckestryke Building & Construction 1 04-27-2006 08:40 PM
