Attic Fan Thermostat - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-30-2013, 09:17 AM   #1
Rewards Points: 12
attic fan thermostat
hi. I have attic fan in my house that was built in the 50's I want to add a thermostat. I have to check it out today it's making noise and want to make control with a thermostat
thank you Alan
cobra1 is offline   Reply With Quote
Old 08-30-2013, 05:33 PM   #2
Rewards Points: 12
the attic fan has power to it and thermostat put now but now motor . I need to know how to wire thermostat to the motor
Old 08-30-2013, 06:12 PM   #3
"the attic fan has power to it and thermostat put now but now motor"
You may want to proofread your post before sending.
First turn off the breaker. Have you mounted the thermostat in an appropriate box?
In the box you'll feed in your hot, neutral, and ground. I'm assuming this is a 120v setup.
Using your thermostat instructions (which override anything I have to say) you'll probably hook the hot to the appropriate wire on the thermostat.
From the thermostat you'll hook up a hot to the fan. In the box you should connect the neutrals and the ground, and ground the box if it's metallic.
RoyalAcresRod is offline   Reply With Quote
Old 08-30-2013, 07:26 PM   #4
Rewards Points: 12,818
If it's also making noise why not get rid of it and add a ridge vent. No more motors, or thermostats to worry about, use's no power and works 24/7 and get the whole roof vented instead of just a circle.
Old 08-30-2013, 07:41 PM   #5
Joe has a real good point: especially in a house built in the 50s. Many of those are not air-sealed real well.
And the attic fan can pull quite a bit of conditioned air from the living space into the attic. Especially if you have insufficient air intake into the attic.
The fan WILL get it's air from somewhere. Likely from inside your home b
Old 08-30-2013, 07:57 PM   #6
Rewards Points: 5,974
My guess is if it's making noise it's days are numbered.
Old 08-31-2013, 09:28 AM   #7
Rewards Points: 12
hi, the fan is in the middle of the house works great I have a high and low switch, on/off. no thermostat. on each gable I have fans with thermostats and 4 roof vents. I just got the house and trying to find out system I have?
the thermostat I will have to check how the thermostat are old hung on a rafter at each side
Old 08-31-2013, 11:31 AM   #8
Rewards Points: 12
got it working
well I did some checking around and found a wall switch that controls the gable fan it must be a 3 way switch with the thermostat. It works great now. would all the fans be over kill? maybe not it should work great now. we shall see, in the mid 90's today. oh can I use my swamp cooler with the fans on to. should I keep some window open to?
thanks for your help this a great site for help
Old 08-31-2013, 11:49 AM   #9
Perhaps it's just me, but I'm having trouble understanding. How many attic fans do you have? I'm concerned you don't have enough intake area to match your exhaust CFM, thus pulling conditioned air from inside your home.
I don't understand why you would want to open your windows with your swamp coolers operating. Where are you located ?
Please add your location to your profile. I'm guessing you're in a dry area? Swamp coolers don't work well in humid climates.
Old 08-31-2013, 12:07 PM   #10
Rewards Points: 12
I live in Lakewood Co.
I have two fans one in hallway ceiling and one on gable, the other gable is a vent and two on roof vents. we average 10%- 20% humidity
Old 08-31-2013, 12:26 PM   #11
Oh, OK, you're talking about two different types of fans. The one in the hallway is a whole house fan. When that one is operating, yes, you'll want to open window(s).
Old 08-31-2013, 12:55 PM   #12
Rewards Points: 12
do you think this is a good system for where we live. and we have a swamp cooler to. the house is about 1200 sq ft
Old 08-31-2013, 12:58 PM   #13
Well if it keeps you comfortable I'd use it. But I have no experience with swamp coolers. Or how to size them.
Old 08-31-2013, 01:02 PM   #14
Rewards Points: 12
it does what we want. with out paying high A/C cost that other pay
Old 08-31-2013, 01:04 PM   #15
Rewards Points: 12
I should do better now that it is all working now
Thank you for the help Alan
Attic fan using z-wave thermostat C03T07C12 HVAC 1 05-28-2013 10:44 PM
Attic Fan Thermostat Issue MJG196 Building & Construction 2 04-24-2013 10:18 PM
Attic project - Would like opinions whataboutj Insulation 6 06-29-2011 04:07 PM
Ventilating attic with two roofs senorbungle Building & Construction 2 01-09-2011 05:17 PM
Powered Attic Fan question spup345 Roofing/Siding 9 06-30-2008 09:10 PM
