Attic Fan Directions?! - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-08-2007, 10:47 AM   #1
attic fan directions?!
Okay, this may be real stupid, but which way are my attic fans supposed to be blowing? I have 1 in the garage, and one on the other side of the house in the attic. The garage one is positioned outwards (and works! It wasn't working but I just rewired it and it does work which is sweet!!!).
My gut tells me to have the other one, the one that's at the far end of the attic, blowing *in*, to push the air in 1 direction across my house, and also because it seems it'd be much more efficient blowing the air in than pushing it out. But then I started thinking that if it's raining and it blows in, I may be doing real harm.
Any tips appreciated!
joeyboy is offline   Reply With Quote
Old 09-08-2007, 11:04 AM   #2
Eibwen
They should both be blowing out for the reason you suggested on the rain.
I assume they are gable fans at the peak of each end of the house. Thier main function is to draw air from the soffits up into the attic and out thru the fans.
They never seem to last long either... I check mine every year to see if they are still functioning.
Sammy is offline   Reply With Quote
Old 09-08-2007, 11:26 AM   #3
Cool thanks for the help!
BTW, any way to make them last longer? The one that was in place when I moved in never functioned. I checked it out and the wiring on it was crap, I rewired it and it worked fine, but the thing is LOUD!!! I was thinking of spraying some wd40 on it but have no idea where to lol!
Old 09-08-2007, 11:38 AM   #4
Eibwen
Your welcome!
Most of the bearings are sealed on the motors so lube is pretty much out.
If the wiring is good its normally the motor thats goes so I always tag mine with where I got the last one to avoid having to replace everything versus just the motor since they do vary.
Some of the noise may be from the air hitting the grille in front of the fan.
You sure are busy today! Doors and fans.
I was just out in the garage reworking my do list. The nice to do, really should do, and GOTTA do..
I'm covered in DOOOOOOO!
Old 09-08-2007, 11:53 AM   #5
Originally Posted by Sammy View Post
Your welcome!
HA! I'm sitting here doing my list too lol!!! I always have my daily list on my clipboard, otherwise it's always 'nice to do' projects!! Having a list keeps me in line!
Turns out I must've been high on attic fumes when I crawled up there, because I just peeked up there, and there's no fan at the other end. So, I've got 1 fan, and it's in the garage at the top of the gable, instead of in the attic (hmmm, I wonder why they would've chosen to install in the garage....!). Is it even going to help me reduce AC bills by keeping it wired up just in the garage? I should probably move it to the other end so it's pulling out how attic air instead of hot garage air... but that's more a 'really should do', and I've got waaay too many 'GOTTA do's'!!
Old 09-08-2007, 12:04 PM   #6
Eibwen
Do list is the only way I stay sane... I try and make small jobs on it so I can cross off things and feel like I am making progress!
Most houses only have one gable fan at one end and a vent the same size as the fan at the other end and of course the soffit vents. If the vent fan is only pulling out of the garage and not the attic space then it wouldnt help the attic much which is what you want to cool.
Old 09-08-2007, 12:52 PM   #7
Same here!!! Wow, you kinda know you spend a lil too much time doing diy work when a pleasurable day consists of 'do list' type stuff!! That's how I'd describe a fun day from the past like 4 months, a day where I did 'do list' type stuff and not other things!
Same here again! Here's a tip ya may like - when you make your list, break down the projects into their components, then you get to cross off more stuff!!!
But honestly, sometimes I'll do something that isn't even ready to be done, just to visually see something get done. Like if I'm doing something that's not gonna be finished for a bit (like stucco'ing my house), sometimes I need to just stop, go to home depot, get a dimmer switch and a cool brushed steel plate, and make a light a dimmer instead of a switch. Just things like that, to actually see something finished! Even though it would be quicker to do all the outlets at the same time, sometimes I just need to see something finished you know?!
Then why would whoever installed it put it in the garage? Dumb, lazy, both? I should probably move it then, but that's not too pressing. Kind of a pain though because I'll need to figure out how to tap a wire for power properly before I can do that (the current one isn't even 'final' wired, I just cut the female end of a computer's power cord off, removed sheathing, and wired the fan to that, so it's actually just plugged into the wall right now! I just wanted to test to see if it was broken, or if their wiring sucked. Oh and I know the wire they tapped into is good because I'm using it for a security light which is fine...).
About the soffits - those are vents? Wow, good to know, because when I rent a powerwasher again, which is soon, I was planning to use it to clean those!! Would've flooded my attic!!
Very true... ! Why couldn't it have been installed poorly into that spot instead of the garage?! What purpose would you put it in the garage for unless you had 2 running for a cross breeze or something? Seems like a waste of time and money to buy an attic fan and then install it in the garage, especially when the garage/attic opening is only ~3' X 3' !!!
Old 09-08-2007, 01:14 PM   #8
Eibwen
I'm the same way 10 projects in progress and none all the way finished so the little things done quick are nice.
Check your overhangs and see if you have soffit vents. Some get covered up with vinyl siding which is fine as long as its the vented type. Garage may have been open at one time which is why they put the fan there and later it was closed off.
Old 09-08-2007, 02:24 PM   #9
remodeling pro
I would not worry about this one moving up the list anyway. I have been trying for years to understand the obsession with these ridiculous attic power vents. The only persons who benefit from these things are the guys who get paid to change the motors every year. It has been proven more times than I can count, that they cost more to operate than they will ever save in reduced power usage from your ac, and when you add the costs of replacing motors constantly, you are spending dollars to save nickels. Adequate gable vents or soffit/ridge vent methods cost nothing to operate, and do not have to be repaired almost yearly.
FYI, , they should be blowing out, the purpose of any type of mechanical ventilation is to exhaust the stale air, physics will take care of replacing it.
troubleseeker is offline   Reply With Quote
Old 09-08-2007, 02:44 PM   #10
That's good to know!
I had always heard (I'm new to this stuff, and houses in general, I just moved into my first house from my apartment!) that if the attic isn't ventilated, it raises the AC bill, so having a fan up there will lower bills.
This afternoon when I powered up that thing, jesus, it was so powerful I was surprised, and had to wonder how much it'd truly be saving me in energy costs, given that it's *gotta* be sucking serious juice to move that thing!
That's really good to know, because had you not told me that, I would've wasted a day easily re-installing that unit in my attic! So I owe ya one!
Old 09-08-2007, 02:46 PM   #11
!!!!!!!!!! I just realized the silver lining here! Because that thing is currently in my garage, and like I said I have it ghetto-rigged up to a power cord and plugged in, I can just unplug it and leave it *until* I'm doing stuff like painting/staining/etc in the garage (which is pretty frequent) and now I have even more ventilation in my 'shop' when I want it!
Attic Smell from A/C - I'm at wit's end! cidsamuth HVAC 19 08-23-2016 05:36 AM
Ranting about attic work IvoryRing Electrical 6 04-16-2008 07:21 AM
Proper Attic Insulation reikiray Roofing/Siding 5 08-04-2007 10:59 AM
Running Romex in the attic mdalli Electrical 7 07-06-2006 05:35 PM
Air duck from basement to the attic MageMinds HVAC 2 04-26-2006 12:41 AM
