Attic Access RO - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-18-2010, 08:04 AM   #1
ane
Attic Access RO
In pictures of new attic ladders I see them enclosed in a wood frame. Is this a part of the ladder? In other words, do I ignore the frame that is currently in my attic access when I measure for rough opening? Thank you.
ane is offline   Reply With Quote
Old 04-18-2010, 08:36 AM   #2
gmhammes's Avatar
I had to reframe my attic opening when i installed my stairs as the current opening was much smaller. the instructions with the stairs should tell you what the opening frame size needs to be.
I don't know if that answered your question but thought it may help.
gmhammes is offline   Reply With Quote
Old 04-18-2010, 02:26 PM   #3
remodeling pro
Yes the frame is part of the assembly. Typical RO for the majority of residential stairs if 25 1/2" x 54", but it is best to either purchase or at least know what you are going to purchase, and verify before modifying the existing framing, as the are many options for stairs that vary from this ,such as narrower units made to fit between 24" truss spacing, short units that only require 48" openings, oversize heavy duty units that are bigger, etc.
troubleseeker is offline   Reply With Quote
Installing and attic access and a "What is this?" cbaileyau General DIY Discussions 16 12-19-2009 02:54 PM
Ceiling Fan and Recessed Lighting with No Attic Access...Ugh. caps84 Electrical 1 08-06-2009 10:09 AM
Moving Attic Access -- Same Rafter or Different ?? wrldruler Carpentry 1 10-19-2008 06:03 PM
Attic fan in Attic access door kubotaart HVAC 10 09-17-2008 12:55 PM
How to seal my attic access - airtight? akoch General DIY Discussions 4 09-08-2008 08:03 PM
