Attaching A Wood Sub-floor To Old Linoleum - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-28-2009, 05:12 PM   #1
Attaching a wood sub-floor to old linoleum
I have a small foyer that has an existing vinyl floor. I want to put new vinyl over it. I want to attach a sub-floor first. 1/4 or 3/16 plywood. How do I attach that subfloor? Glue? Nails?
Thank you!
Web
user59291 is offline   Reply With Quote
Old 07-28-2009, 07:51 PM   #2
Rewards Points: 16
Why are you wanting to add another layer of subfloor instead of riping out the old vinyl? I personally don't like just adding layers to cover up what is there. I would rather take the time to rip out the old before the new goes in. Unless you are looking to raise the floor height.
I have never layed vinyl but have seen others use 1/4" luan and staple it down with a TON of staples!
ponch37300 is offline   Reply With Quote
Old 07-29-2009, 06:57 AM   #3
Perhaps I wasn't clear...
The concrete under the existing floor is not very smooth. It is for this reason that the current vinyl flooring is in the condition it's in.
I see it best to make a flat area first and to add a thin plywood sub-floor may be my best option. Unless you know of another. Please don't tell me to correct the cement, It isn't that bad. Just bad enough to ruin the layer put on top.
But I don't want to remove the old flooring if I am just going to cover it anyway, It's on pretty good.
Make sense?
Thank you!
Web
Old 07-29-2009, 07:46 AM   #4
Putting a thin luan/plywood layer over an old floor is a common fix
My last house had 12 layers of flooring in the kitchen
I'm not sure if 1/4 will be thick enough to prevent another problem
Old 07-29-2009, 08:00 AM   #5
I don't have any serious peaks or valleys from this concrete. It just a few "rough" areas.
If I cut the sub-floor to size (the room is only 4x6) so that it is "one" piece, will glue do the job? Any suggestions on a type of glue?
Common sense tells me that nailing thin plywood to concrete would be no good. Especially when I want it as smooth as possible. But I'm not looking for perfection. It's only a mud-room.
Web
Old 07-29-2009, 09:34 AM   #6
Rewards Points: 16
I see now that you explained a little better. Glue sounds like a good plan.
Sometimes I do things the hard way. Like ripping everything out and fixing the problem. This way I know I am starting fresh and it will be done right. Sometimes this is overkill but that's just how I am!
Old 07-29-2009, 09:51 AM   #7
Thank you!
Any suggestions on the type of adhesive that is best for this situation?
Web
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 03:59 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 10:14 AM
Removing Linoleum backing paper from wood floors SatDoug Flooring 4 09-17-2006 12:00 AM
linoleum on wood? daustin555 Flooring 2 05-28-2006 11:25 AM
