Attaching Radiant Heat Plumbing To Wall - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-17-2010, 10:16 AM   #1
attaching radiant heat plumbing to wall
This is kind of a silly question, but what is the best way to attach the piping, valves, pumps, etc. for a radiant heat system to the wall?
I put up a sheet of 3/4" plywood on the wall as a base and have the boiler attached to the studs through the plywood. The majority of the pipe is 1" copper and the pump requires about 2" of stand-off for the flanges to clear. I purchased some copper bells for the pipe, but they only provide about 1" of standoff.
I can put a small piece of wood behind the bell to get enough stand-off, but was hoping there was a more elegant solution.
Thanks in advance for your help.
skipaola is offline   Reply With Quote
Old 11-17-2010, 10:21 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,012
Ayuh,... I built my own stand that's tap-con'ed to the concrete...
Uni-strut is some pretty neat stuff to work with...
Old 11-17-2010, 10:36 AM   #3
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Old hockey pucks are 1" thick ????
tcleve4911 is offline   Reply With Quote
Old 11-17-2010, 02:31 PM   #4
Like the hockey puck idea but they are hard to come by in kansas. :-) I'll take a look at unistrut.
How to stop auxillary heat from coming on defrost cycle and limit auxillary heat use? twilightcall HVAC 34 12-28-2010 06:53 PM
Attaching fence post to side of retaining wall? Drew328i Landscaping & Lawn Care 5 06-01-2010 07:53 AM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 10:32 AM
Radiant floor heat question. ingeborgdot Remodeling 6 03-23-2010 12:05 PM
Radiant heat question tpagel HVAC 4 05-21-2008 04:57 PM
