Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 08-12-2012, 07:51 PM   #1
Attach fabric to mdf
Need to attach fabrics to mdf and then put molding around the mdf like a picture frame. The mdf will b 1/2 inch how would you recommend attaching the fabric. This is going on a easel for a wedding.
dvatt is offline   Reply With Quote
Old 08-12-2012, 08:05 PM   #2
I would try this.
http://www.scotchbrand.com/wps/porta...glG7BT57N7SHbl
Lowes and Home Depot have it. May find it in the sheetrock area or paint area.
Old 08-12-2012, 08:19 PM   #3
I want to somehow attach the fabric and then on top of the fabric install the molding which will be three inches wide around.
Old 08-12-2012, 08:50 PM   #4
Stretch the fabric over the MDF and staple in back. Or use spray mount, like Super 77.
7echo is offline   Reply With Quote
The Following 2 Users Say Thank You to 7echo For This Useful Post:
1910NE (08-14-2012), oh'mike (08-12-2012)
Old 08-12-2012, 08:56 PM   #5
Can you get spray 77 at home depot? Also how would you staple the back with a pneumatic staple gun?
Old 08-12-2012, 09:42 PM   #6
just use the spray adhesive. put a mist coat on the fabric and the mdf. let it dry for a few minutes, then carefully lay the fabric down on the mdf. let that dry for about 15 mins. then flip the board over and spray the fabric and board, let that dry a minute. then fold the fabric over the edges to the back. . = done.
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
Fix'n it is online now   Reply With Quote
Old 08-12-2012, 10:39 PM   #7
Super Moderator
Simply staple and stretch it--no glue needed at all---
My dad was a display man and I helped stretch fabric like this many times---you will be fine---
Old 08-13-2012, 08:07 AM   #8
Staple using what?
Old 08-13-2012, 08:18 AM   #9
Originally Posted by dvatt View Post
Staple using what?
Somewhat dependent on how tight the weave is, but a standard hand stapler with a 1/2" crown should be fine. A T-50 stapler would probably work.
Old 08-13-2012, 08:43 AM   #10
Super Moderator
Exactly---A t-50 or even a lighter duty staple will work just fine---
Old 09-01-2012, 05:32 PM   #11
Bombastic Idiot
notmrjohn's Avatar
Say, folks that Supe'r 77 sed it had "Fast, aggressive tack" How fast? Is dvatt gonna have a problem smoothing out wrinkles? Maybe Fix'n's careful laying should be done by 2 people holding the corners ? Or laying the cloth over a thin pad, few layers of newspaper with brown paper barrier on top, smoothly stertch and tack cloth over that and lower board onto cloth?
Measure twice, cut once.
Look at the nail, not the hammer. Watch the fence, not the blade.
If you hook your thumb over your belt you won't hit it with the hammer or leave it layin on the saw table.
notmrjohn is offline   Reply With Quote
Deck: how to attach stringers 10Thumbs Building & Construction 6 06-08-2011 01:35 PM
Alternatives to landscape fabric? ricksample Landscaping & Lawn Care 10 02-01-2011 04:18 PM
Framing - How should I attach top plate? NEW-B Building & Construction 1 01-13-2011 09:13 AM
Attach Drywall through plywood HooKooDooKu Drywall & Plaster 2 01-20-2010 11:05 PM
How to best attach heavy iron stair railings to home with vinyl siding Alfredo Building & Construction 1 05-18-2008 08:16 AM
