Asphalt Driveway Cold Patch And Sealing - General DIY Discussions - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By Blazepet7
  • 1 Post By Bondo
Old 04-27-2010, 09:18 AM   #1
DIYguy2000's Avatar
Rewards Points: 93
Asphalt Driveway Cold Patch and Sealing
I'm waiting for a few nice days in a row to fill in the cracks in my driveway and seal it. The asphalt has settled about 1/2" to 1" in front of the garage and I was planning on placing some cold patch.
1) There's also a depression (about 16" in diameter) in the middle of the driveway about 1" to 2" deep. Can I use cold patch to fill the depression? or will it look terrible after? I live in Ontario, Canada, how would this hold up in the winter with shoveling?
2) Can I also fill in a part of the gutter/curb between my driveway and the road? or does the City not allow this?
3) I've also heard that a broom may be better than a roller for applying the sealant. any suggestions?
Thanks!
DIYguy2000 is offline   Reply With Quote
Old 04-28-2010, 05:54 AM   #2
No expert on that stuff, have used it a few times. Sometimes it works, sometimes it does not stick well. It always looks like a patch. Applying sealer works well with a brush or squeagee. Rollers don't really work as well.
Old 04-28-2010, 07:48 AM   #3
I dont reccomend cold patch for a permanent fix for the summer it may work but coldpatch dosent like water it probably wont last you too long. I am a union excavator and work with it alot and it all depends on how well you tamper it, shoveling it may pull it up. If you have to use it go to the asphalt plant near you and get the stuff made there instead of the bagged that you buy in store...
Bondo likes this.
Blazepet7 is offline   Reply With Quote
Old 10-29-2010, 01:30 AM   #4
Cold Patch is Better Option
Hi,
1)yes, you can use Cold Patch to fill depression and it wont look terrible.It may hold for your long time so need to worry .
2)No, I don't think city would allow you to Block that gutter.
3)ya ...me too think so but i am not sure :):)
Thanks!
Gloriaray is offline   Reply With Quote
Old 04-12-2017, 12:29 AM   #5
Rewards Points: 2
Re: Asphalt Driveway Cold Patch and Sealing
How long should one wait before sealing a fairly large cold patch repair
Pilgrimpaver is offline   Reply With Quote
Old 04-12-2017, 06:11 AM   #6
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,726
Ayuh,.... It don't really matter,....
Cold patch is junk, 'n won't last anyways,....
Msradell likes this.
Driveway prep Ultrarunner2017 Building & Construction 2 10-11-2009 11:51 AM
concrete driveway debd Building & Construction 7 09-29-2009 01:39 AM
Bad driveway patch and seal work fastfan Landscaping & Lawn Care 1 09-09-2009 08:14 PM
Garage concrete and driveway asphalt repairs creamaster Building & Construction 4 07-12-2008 10:51 PM
