Aquatec Permeate Pump Noise, Reverse Osmosis - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-01-2010, 08:52 PM   #1
Hello, first timers here!
I've scoured the internet for someone with a similar problem...but I've found nothing....So I'm hoping that maybe someone here has heard of this:
I have an Aquatec permeate pump connected to my reverse osmosis system.
The dealers sell this as a "booster" pump for households with well systems...or at least that's how it was sold to me...
I'm on my 2nd pump now....
After some time the pump starts to rattle and shake, and make a loud noise that I can only describe as a machine gun sound.
I am on a well system, with a pump and a pressure bladder system, along with a softener....
Any ideas??
nissmo66 is offline   Reply With Quote
Old 01-16-2012, 02:19 PM   #2
I experienced a similar problem with my Aquatec permeate pump. I contacted Aquatec and spoke with a tech. Assuming everything is properly hooked up and the restriction valve is in fact ahead of the pump input, then the culprit is probably a broken spring inside the pump unit. Based on where in the country reports of the problem come from, it appears to be associated with high iron content in the water supply. Aquatec will replace the pump in accordance with its 2 year warranty.
Greg73 is offline   Reply With Quote
Old 01-16-2012, 02:20 PM   #3
I experienced a similar problem with my Aquatec permeate pump. I contacted Aquatec and spoke with a tech. Assuming everything is properly hooked up and the restriction valve is in fact ahead of the pump input, then the culprit is probably a broken spring inside the pump unit. Based on where in the country reports of the problem come from, it appears to be associated with high iron content in the water supply. Aquatec will replace the pump in accordance with its 2 year warranty.[/QUOTE]
Sump Pump Questions henlij Plumbing 22 03-16-2015 11:00 PM
Sump Pump Noise - Please Help! dcusk1971 Plumbing 10 03-21-2011 09:02 PM
Well Pump Problems dannyjoe Plumbing 6 10-01-2009 07:10 PM
Kinetico Water Softeners -Reverse Osmosis Questions...Help - Advice wanted.. OverRunWithSons Plumbing 7 07-26-2009 01:14 AM
Taco IFC pump makes noise when it stops Addicted HVAC 21 04-14-2009 01:59 PM
