Applying Strapping To Concrete - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-17-2013, 12:07 PM   #1
Applying Strapping to Concrete
I am in process of renovating my basement, my house is new < 12 months old.
I am trying to determine the best way to attach drywall to a concrete wall. I have the concrete wall lined with the Formular pink polystyrene foam board. My plan is to attach 1x3 strapping to the concrete wall and foam board and then screw the drywall directly to the strapping. My house is fully insulated already and these are only inside concrete walls. The outside concrete walls I built a wall, insulated and all that good stuff.
So what is the best and easiest way to attach the 1x3 strapping to the concrete wall? I know the hammer drill will work but that's hard work. Is there an easier way like a ramshot or hilti gun? Will that work with 1x3 strapping. I was thinking that one of these guns might go right through the strapping.
Any useful tips?
dblandfo is offline   Reply With Quote
Old 10-29-2013, 05:32 AM   #2
Cruising into the sunset
JulieMor's Avatar
Rewards Points: 518
If you're still with us...
I used a Hilti when installing 2x2 furring to my concrete foundation wall. I'm pretty sure I used yellow shots. I've shot 1x lumber but if you don't pre-drill it, it could easily blow through.
JulieMor is offline   Reply With Quote
Old 10-31-2013, 01:54 PM   #3
Rewards Points: 274
I think hilti gun is suitable.
alexjoe is offline   Reply With Quote
Concrete and Brick Repairs spidercharm Building & Construction 6 08-26-2012 04:15 PM
garden shed on existing concrete pad hartkem Building & Construction 6 10-27-2011 08:46 PM
Bamboo on modified concrete pad jhanson Flooring 0 10-08-2011 11:58 AM
New Concrete Walkway along side of house braverichard Building & Construction 0 11-03-2010 11:12 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
