Apartment - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-05-2008, 12:42 PM   #1
Question
apartment
I have some concrete walls I want to texture coat. I have a Spraying Mantis and I was wondering if you could spray a stucco mixture through the gun. Has any one got any ideas? Thanks
Drinkingrubberduck is offline   Reply With Quote
Old 07-05-2008, 02:39 PM   #2
Registered User
Termite's Avatar
Actual stucco finishes are not sprayed. Much too thick to spray.
Drywall mud can be thinned and sprayed using a hopper and texture gun. Common finishes are the old popcorn look and various knockdown techniques. Perhaps you could properly prep the wall and do something like that.
I think your best bet would be to actually trowel stucco on conventionally if that's the look you're going for.
Old 07-06-2008, 10:37 AM   #3
Talking
apartment
Thanks for the info. I guess I will use the mud. I live in the Virgin Islands and it is very moist from the ocean breezes and I was worried about that. But I hate stucco by hand.
apartment: 3-pronged, ungrounded outlets pro_DIYer Electrical 9 10-15-2008 05:22 PM
modern apartment/ spots are flickering graham in dublin Electrical 4 05-16-2008 12:30 PM
Steel I-Beam Choice for Aircraft Hangar Apartment diy-581 Building & Construction 16 02-04-2008 10:15 AM
What is apartment grade carpet? darsunt Flooring 4 06-05-2007 06:50 AM
Garage Apartment LoriMD Remodeling 1 01-17-2007 09:30 PM
