Anyone Know How Float Switches Work? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-11-2014, 06:53 PM   #1
Rewards Points: 1,062
Anyone know how float switches work?
Have one of these:
http://www.ebay.com/itm/Teel-Float-S...item19e9970405
It hangs inside a 200 gal di water tank, and when the di water pump is done filling up the tank and reaches a certain level, that switch is supposed to shut of the pump motor. Thing is, now, its not working.
I pulled it out of the tank, and jostled it around a bit and, with motor on, still pumping, it shut off the motor intermittently. There is water INSIDE this thing!!! Is that normal, people?? Water inside a shut off switch?
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 04-11-2014, 07:19 PM   #2
Rewards Points: 1,694
Water inside is not normal. It's obviously holed somewhere and the water inside is oxidizing the contacts.
You need to replace it.
Bob Sanders is online now   Reply With Quote
The Following User Says Thank You to Bob Sanders For This Useful Post:
noquacks (04-11-2014)
Old 04-11-2014, 07:32 PM   #3
makes sense- just wanted to ask to be sure......
Old 04-11-2014, 08:45 PM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 830
The old ones had a mercury switch in it....not sure how the newer ones do it...
Anyway...the cord needs to be attached to the side of the tank just below the level you want.
As the tank fills up, the cord causes the float to point up...that trips the gravity switch.
A little water is ok....the switch should be sealed. If the float still floats...then it should work
Rotate the float up. With it in the up (cord down position), if your getting intermittent operation....the switch is bad. That was the nice thing about the old mercury ones...they didn't wear out.
ddawg16 is online now   Reply With Quote
Old 04-11-2014, 11:00 PM   #5
Rewards Points: 920
I know how these switches work and the answer is they don't work worth a damn. I think the new float/switch assembly costs probably $25 and a new pump will run $60. I've replaced a lot of switches and not a lot of pumps.
cleveman is offline   Reply With Quote
None of my wall switches work today. Worked when I went to bed. Have never had problems before. IllinoisMel Electrical 3 10-09-2012 06:30 PM
Light switches won't work Allan6rc Electrical 5 09-19-2012 11:10 PM
New work vs Old work Tetranitrate Electrical 3 07-12-2011 09:19 AM
Question about switches on a 20 amp circuit Abs777 Electrical 6 04-28-2010 11:09 AM
Outlets Work - Switches Do Not? Quick Electrical 6 08-13-2008 05:10 PM
