Anyone Know Anything About AC Units Need Help Bad - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-27-2010, 11:16 PM   #1
Anyone know anything about AC units need help bad
My ac is acting up. The vents on the main level have no air coming out of them at all but my basement on the other hand is blowing out perfectly good cold air.
I have no clue really where to start looking and my 6 month old is not happy about our 95 degree house. If anyone could give me some insight on where to start id appreciate it.
I also posted this in the HVAC section i just need answers fast.
Jon238 is offline   Reply With Quote
Old 07-28-2010, 05:58 AM   #2
Lines coming off main trunks usually have damper flappers in them. They may be closed, diverting all air to the ones that are open. It is usually a metal handle coming out of the side of the duct. The direction of the handle indicates the direction of the damper valve. And air vents also have dampers, make sure they are open.
Old 07-31-2010, 01:17 PM   #3
Besides the dampers in the duct work, diffusers usually have a way of limiting the air flow. Make sure that these have not been closed off.
eHow has an article about this!
How to compare HVAC units of diff efficiency and same capacity tomseeley HVAC 3 03-13-2010 05:11 AM
Need HVAC solution for basement - 3 zone? or ductless units? skylake HVAC 2 10-06-2009 07:42 PM
Stacked washer & dryer units janralix Plumbing 4 08-06-2009 04:00 PM
5 ton unit or 2 seperate units allenky HVAC 1 06-06-2009 05:35 PM
Need to build enclosure for multiple outside a/c units. firedudesgirl Carpentry 4 03-31-2009 06:10 PM
