Anyone Ever Put Formica Over Cultured Marble? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-18-2010, 04:24 PM   #1
Anyone ever put formica over cultured marble?
Has anyone ever put formica over cultured marble? Not the preformed particle board counters but just the bare sheet formica. I've got an old bathroom vanity that works fine but the counter is this old ugly cultured marble. I'm looking for a quick temp fix and figured I could just pop the sinks out put a sheet of formica on top and an edge banding and be done with it?
Thoughts?
B
b_corwin is offline   Reply With Quote
Old 01-18-2010, 04:32 PM   #2
Rewards Points: 768
The only thing I would worry about is adhering the laminate to the marble. If you're going to all the work tearing the sink out. Why not the marble too and replace with particle board and then laminate?
cibula11 is offline   Reply With Quote
Old 01-18-2010, 04:48 PM   #3
Too Short? Cut it Again!
Agreed. Getting the adhesive to stick would be the issue and why not just redo the countertop if you are ripping the sink(s) out. Will not be that much more expensive. One of the new stone counter overlay companies might be an option for you too?
Old 01-18-2010, 07:34 PM   #4
Rewards Points: 5,336
Just replace the countertop.
Ron
Old 01-20-2010, 02:35 PM   #5
indeed
Took the sound advice and tore out the old counter and re sheeted and banded with 3/4" ac ply.
Thanks,
B
painting cultured marble debden55 Painting 7 02-27-2014 12:32 PM
Granite tile over cultured marble? stage kat Flooring 3 05-07-2011 03:46 PM
Fixing Unlevel cultured marble bath tub/shower fredk Plumbing 1 12-01-2009 10:13 PM
Noise, hollow, movement on cultured marble floor...need help? handfix2008 General DIY Discussions 8 11-04-2008 09:25 PM
