Anybody Work With Numbered Drills Smaller Than 0.0625"? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-16-2010, 05:58 PM   #1
Anybody work with numbered drills smaller than 0.0625"?
What kind of drill do you use?
B&D said their drill motor chucks cannot reliably hold drills smaller than 1/16".
Old 07-16-2010, 06:06 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
a drill with a smaller chuck, or if one is available, buy a smaller chuck for the drill you have
they make 1/4" chucks and 5/32" chucks. Don't know if they make them for your drill but that is what you need.
Old 07-16-2010, 06:52 PM   #3
kwikfishron's Avatar
Rewards Points: 82
How often do you need to drill a hole smaller than a 1/16”.
I don’t think I ever have.
kwikfishron is online now   Reply With Quote
Old 07-16-2010, 09:31 PM   #4
Originally Posted by kwikfishron View Post
How often do you need to drill a hole smaller than a 1/16Ē.
I donít think I ever have.
It comes up very occasionally for me.
Usually I use a brad with the head cut off when I need a bit this small.
My Rockler catalog came today and they have drill bits and a compatible chuck for $16 or so, but I first have to check a handdrill chuck that I have in the basement. If it can hold #30 AWG wire wrap wire it can certainly hold these numbered bits.
Thanks, guys. . .
Old 07-17-2010, 03:49 PM   #5
Household Handyman
Rewards Points: 1,408
"Anybody work with numbered drills smaller than 0.0625"
Probably should not answer this but I will, because I was a machinist for 38 years--YES, I have worked with drill bits less than 0.0625", and often. You may not find a compatible drill chuck for holding drill bits smaller than this which will allow the drill bit to rotate accurately. I have drill chucks which will hold drill bits at 0.0003", and the drill bits. BUT--since retirement I certainly don't have access to any equipment to use these. I just like to keep them in their cute little plastic case to show people. IMO--I would say that with normal, average, DIY equipment, around-the-house, you may find that a 1/32" (0.03125") drill bit to be the best you can do, IF you are very careful with it. David
Old 07-22-2010, 07:43 AM   #6
An old Tradesmen
Rewards Points: 6,068
For drilling some smaller orifices. My DeWalt won't hold the bit.
So have to use a chuck in its chuck.
One of these should work for you.
http://www.amazon.com/DRILL-CHUCK-AR.../dp/B000HXOER0
http://www.buy.com/prod/pin-chuck-vi...213585295.html
http://www.amazon.com/Jacobs-drill-c.../dp/B0002BK3WC
Old 07-22-2010, 01:41 PM   #7
You guys are better than the Rockler catalog.
Old 07-22-2010, 02:15 PM   #8
Rewards Points: 249
I've worked with carburetors that required a drill bits that looked like they'd snap if the wind hit them. They're one of those things you buy, and maybe use a few times in your lifetime (unless it's your job, like Thurman). BeenThere is right on with his links on products to hold the small bits.
Durt Ferguson is offline   Reply With Quote
handling unsafe work by an electrician wuxingming57 Electrical 1 11-14-2009 08:07 PM
Duct work in garage. flashme18 HVAC 1 11-08-2009 07:29 PM
Where are the "Carpenters" ???? wrldruler Carpentry 14 09-11-2008 08:37 AM
HVAC contractor ripoff! sekntonone HVAC 8 04-05-2008 08:15 AM
