Any Way To Smooth Concrete Walls? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-10-2008, 07:37 PM   #1
Any way to smooth concrete walls?
Hi -
We're working on "finishing" our basement - we have a poured concrete basement and the walls have frames and paneling up. The problem lies in the stairwell - one side is drywall which is great, the other is the poured concrete which is really rough - rough enough to take skin off if you rub against it. Since the environment needs to be kid friendly, I've been trying to figure out a way to smooth out the wall - just enough to not be so sharp. It doesn't have to be completely smooth. An employee at my local home improvement store suggested an electric sander...not going to work because the peaks of the concrete will rip the sandpaper to shreds. Any other ideas? Thanks!
SarahM is offline   Reply With Quote
Old 04-10-2008, 08:19 PM   #2
ICF Construction
Parge coat will help level it out and smooth it somewhat, but it's concrete and hitting it hard will hurt. Maybe laminate drywall to it??
Chris
Chris Johnson is offline   Reply With Quote
Old 04-10-2008, 08:32 PM   #3
joed's Avatar
Rewards Points: 12,430
Angle grinder with a concrete wheel will do it. It will be very dusty and depending on how much you need to grind, very time consuming.
If the concrete is bare and clean then a parge coat is probably the easiest.
How rough is it? Maybe one of those epoxy coatings you use on garage floors would work?
repairing concrete patio flooring & attached walls 1655graff Remodeling 2 01-21-2009 12:21 PM
How to make a concrete floor smooth? drh Flooring 13 02-10-2008 12:59 PM
Walls on Concrete flyultralite Building & Construction 12 11-21-2007 08:29 PM
Working around pipes on concrete walls lemones Remodeling 1 10-11-2007 10:08 AM
Concrete walls on wooden joists stonehanger Building & Construction 3 11-24-2006 04:26 PM
