Any Tips For Cutting Stainless Steel? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-11-2013, 10:15 PM   #1
Any tips for cutting stainless steel?
I need to cut some .020" (25 gauge) stainless steel trim.
http://newyorkmetal.com/pc-238-18-ss...-moulding.aspx
Mostly it will be straight cuts - cutting to length, cutting off a small part of one side, etc. The trickiest part will be two 90 degree bends. Can anyone suggest the best tools to use. I have metal shears and can rent any power tools (cutoffs, etc.) that would be useful. I have a Dremel, if that would be any good for touch-up grinding to clean up burrs. Any ideas?
Bunburryist2 is offline   Reply With Quote
Old 08-11-2013, 10:22 PM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 1,810
A band saw would be best.
Next...a Sawzall with a good metal blade.
Old 08-12-2013, 06:05 AM   #3
Rewards Points: 13,694
Even a hack saw will work. Stainless is a soft metal.
Is it just me or does anyone else see there's not going to be anyway to bend a piece of metal that shape without destroying it.
Old 08-12-2013, 06:17 AM   #4
bbo
I think he means just cutting through the bend.
bbo is offline   Reply With Quote
Old 08-12-2013, 07:30 AM   #5
kwikfishron's Avatar
Rewards Points: 576
I'd use a jigsaw with the finest tooth metal blade on the shelve.
A piece of masking tape on the cut area will help with marking and seeing the cut. Clamping the piece will help a lot too.
kwikfishron is online now   Reply With Quote
Old 08-12-2013, 07:31 AM   #6
firehawkmph's Avatar
Rewards Points: 1,884
If its just a few cuts, I agree with the hacksaw approach. Get a good blade like a Lennox, with very fine teeth, 24 tip. Less chance for damage vs. using a power tool. Plus you'll get a cut with hardly any burr.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 08-22-2013, 06:29 AM   #7
Rewards Points: 3,130
Not exactly the same situation, but the wife decided she wanted a kitchen backsplash made of the trendy (and spendy) 16-gauge stainless steel tiles. I used my miter saw to cut them. No special blade, just the regular 24-tooth one that was already on it. Did have to replace the blade when I was done but was planning on replacing it anyway.
Old 08-22-2013, 02:31 PM   #8
Shandre''s Avatar
Hi guys, sorry to jump in...but u mentioned cutting stainless steel, that's like corrugated iron, right? With a jigsaw...with a metal cutting blade?
I thought I could only use my jigsaw to cut wood
Pls tell me more abt the type of blade to ask for art the hardware
Shandre' is offline   Reply With Quote
Old 08-22-2013, 07:42 PM   #9
With the right blade, a jigsaw will most certainly cut metal. They are called, oddly enough, metal-cutting blades.
Old 08-23-2013, 02:34 AM   #10
Shandre''s Avatar
...ok...cool. and I suppose it only cuts soft metal.
It's still have to angle grind the metal that a angle iron it's made of
Old 08-23-2013, 09:41 AM   #11
The stainless steel being discussed in this thread is very thin (.020 - .0625 inches). If you want to cut angle iron, you're probably be better off using a reciprocating saw (generically called a Sawzall). There are metal-cutting blades for them as well.
Old 08-23-2013, 09:49 AM   #12
K&B Designer
Live_Oak's Avatar
Bunch of wimps! How come no one mentioned using a plasma cutter!
Live_Oak is offline   Reply With Quote
The Following User Says Thank You to Live_Oak For This Useful Post:
ThatDaveGuy (03-03-2014)
Old 08-23-2013, 03:22 PM   #13
Rewards Points: 980
Why are you so skeptical? It will work fine on angle iron.
An angle grinder is probably easier if you don't mind a rough cut.
Toller is offline   Reply With Quote
Old 03-02-2014, 01:51 PM   #14
Rewards Points: 378
Cutting s/s will be easier if you use a spray bottle filled with water. The water will keep the metal cool and flush the metal particles away. Can you clamp wood as a guide for the cutting tool. Don't buy cheap blades, use Lennox or Milwaukie
fireguy is offline   Reply With Quote
Loose stainless steel deck screws drtbk4ever Building & Construction 17 06-19-2012 09:26 AM
How to clean stainless steel grill?? JohnnyD44 Appliances 2 07-21-2011 08:32 AM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 04:24 PM
HELP with 1" stainless steel tile, can't cut! blakekr Remodeling 1 05-13-2008 09:20 PM
Current trends: Cast Iron or Stainless Steel sink? Fat b Remodeling 4 05-04-2007 07:09 PM
