Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 07-25-2012, 05:44 PM   #1
Any thoughts on hanging a foot pedal on porch swing?
I was lucky enough to inherit a porch swing that hung on my great-grandfather's home during the 1940s (probably before that too but can't verify). Only after I hung it did I realize that there's a foot pedal that will also be connected to the ceiling via chain. The pedal allows the person on the swing to propel the swing with his feet. I'm having trouble determining how much support is required where the chain will tie into the ceiling. The foot pedal will "float" in front of the swing. Because of the swinging motion when stepped upon, I can't imagine anybody being able to balance their full weight on just the foot pedal. The porch ceiling is 3/4 inch tongue and groove beadboard. Would an eye screw through the ceiling be sufficient? The black swing is mine. The white one provides an example with the foot pedal hung.
tabatt07 is offline   Reply With Quote
Old 07-25-2012, 05:54 PM   #2
You step 'through' the foot petal when sitting then put your feet on it.
Hang it from a beam or rafter. Not just the 1x4 ceiling
mae-ling is offline   Reply With Quote
How to hang swing bench from 4x6 rafter on new porch debn802 General Discussion 15 07-13-2012 01:03 AM
hanging a swing from a concrete beam LarryT Concrete, Stone & Masonry 4 07-01-2012 10:38 PM
Hanging Porch Swing jakate General Discussion 2 05-15-2012 03:57 PM
Hanging drywall on 8.5 foot walls motopokep Drywall & Plaster 8 05-04-2012 09:37 PM
Porch Swing nikeman Building & Construction 21 03-07-2011 08:15 PM
