Any Suggestions? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-06-2013, 09:19 AM   #1
Any suggestions?
My upstairs bathroom has a dirt smell. I clean it and within a few hours it starts smelling like dirt. Maybe, a musty smell but it just doesn't smell clean. It is the only bathroom that has this odor. Anyone have any suggestions on what might be causing it and or how to possibly get rid of it? Thanks.
Candi is offline   Reply With Quote
Old 06-06-2013, 09:57 AM   #2
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
It is possible there is mold in the walls, especially behind the tub or shower.
If this is the case, there is not much you can do short of tearing it all out.
How old is the bathroom? If the shower walls are tiled I would see if any of them have any movement or feel mushy, most likely along the bottom and where most of the water hits.
Also check around the base of the toilet. Make sure it is dry, and see if there is any indication the floor feels soft or rotted.
Just a guess here, but mold is your most likely culprit in an older bathroom.
Old 06-06-2013, 09:58 AM   #3
MarginallyQualified
Rewards Points: 2,464
bathrooms = waste pipes & vents.
Look for drips, leaks, gaps, misaligned fittings... and so forth.
They also mean tile... see if any of them have any movement or feel mushy (as blondesense said)
Old 06-06-2013, 10:41 AM   #4
Rewards Points: 5,974
Also check around the base of toilet. If you find nothing you may need to go in the attic and check may have been an old roof leak that was fixed but the moisture was still there and caused the mold.
Old 06-06-2013, 11:19 AM   #5
Have to agree - sounds like mold somewhere
Hawktomegoose is offline   Reply With Quote
Old 06-06-2013, 11:38 AM   #6
JOATMON
ddawg16's Avatar
Rewards Points: 1,156
Normally, "dirt" does not have a smell. Try smelling a rock sometime. Mold, urine, sewer gas and dead things do.
Can you be more specific with the smell?
ddawg16 is online now   Reply With Quote
Tags
bathroom
Suggestions for my Kitchen ktm General DIY Discussions 7 04-08-2011 09:13 AM
Cheap suggestions for changing look of bathroom sink countertop? mrdazzo7 General DIY Discussions 11 01-07-2011 06:43 PM
Kitchen Cabinet Suggestions + General Kitchen Suggestions ffmariners Interior Decorating 3 08-16-2010 03:41 PM
Color suggestions? kevinc Interior Decorating 2 01-04-2010 05:41 PM
Building a new deck......suggestions? thoughts? Rhizzlebop Building & Construction 38 06-24-2009 06:07 PM
