Any idea how to remove glue from wooden floors
More then likely if you are tying to sand it off, its just "gumming" up on the sand paper (disc or belt).
Scrapping or finding some kind of solvent that will remove the glue but not damage the floor would be something which i would look in to.
If you start to scrap, i would try and move in the same direction for as long as possible, scrapping back and forth might just "roll" the glue around.
If you state what kind of wooden floor (hardwood, plywood, etc.) the glue is stuck to it might help people answer a little better.
~ What was once an opinion, became a fact, to be later proven wrong ~
My current learning experience - To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. - Work shop, music-room, master bedroom above..
