Any Advice On Buying An Antique Home - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-28-2010, 12:39 PM   #1
Any advice on buying an antique home
Besides the obvious pest, mold, rot damage and electrical, plumbing, heating system inspections, is there anything else I should be specifically looking at when viewing properties from this era? I'm concerned the most about structural issues. This paticular house built in 1850 has an old fieldstone foundation, and over the past 160 years of water infiltration into the dirt basement, several major structural components have deteriorated. They sistered up every single joist with 1 or 2 new 2x6's depending on the condition of that particular joist and then added dozens of additional support columns and horizontal headers in the basement to re-support different structural components or areas of the house, basically taking loads that was once on 4 large columns that are rotted away, then transfered the load to about 24 different PT 4x4's wrapping the interior side of the foundation wall. They basically build a new structure under the existing structure using pressure treated 4x6 headers and 4x4 columns set at some unknown depth into the dirt floor. The joists on the first floor that used to rest on the stone wall must've been severly rotted at one point, they cut the joists back about a foot, re-build the entire sill plate on top of the stone wall, then re-supported the first floor with new PT columns in the basement. I'm concerned about these "bandaids" that have been put on the structure over the years. The PT 4x4's are just sitting in the dirt, will these rot away in a few years and i'll have to address the entire structure again in a short time? Is this something you would be concerned about? Everything looks solid, it just looks like a giant bandaid.
Any advice?
The Engineer is offline   Reply With Quote
Old 06-28-2010, 05:12 PM   #2
Rewards Points: 5,336
Have someone qualified look at the house.
Ron
Old 06-28-2010, 05:23 PM   #3
DIY staff
Rewards Points: 7,174
I second that---Have a foundation specialist or a structural engineer size it up.
If your town has a historic commission drop by and have a chat, Some of those guys (and gals)
Will give you the heads up as to who's good. Typically they are not supposed to recommend any one-
However ,if you meet face to face (and nobody else is listening) you should get the info you seek.
----Mike----
Old 06-28-2010, 05:28 PM   #4
Tom Struble's Avatar
Rewards Points: 2,002
lead paint is really an issue
Tom Struble is offline   Reply With Quote
Old 06-28-2010, 05:41 PM   #5
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 148
It can cost you a lot of money, but it's just like the asbestos scare, way overblown.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 06-28-2010, 07:46 PM   #6
And once you have figured out how much it will cost to make repairs, double it and this will give you a ball park figure of the total cost!
The Following User Says Thank You to Wildie For This Useful Post:
oh'mike (06-28-2010)
Old 06-29-2010, 10:45 PM   #7
Rewards Points: 1,016
Don't...
Be way careful of a money pit and huge time consumer.
New pool pump trips breaker?! New home owner needs advice. KenR7A Electrical 22 01-05-2011 09:42 AM
Need Advice ASAP. New home, seller is paying to replace roof elpa Roofing/Siding 4 02-18-2010 07:03 PM
Owning a home (not a mobile home) on leased land? Badfish740 Off Topic 11 03-30-2008 09:34 AM
Need advice...rotten floor joists on house I'm buying strngelitlgrrl General DIY Discussions 5 08-01-2005 09:14 PM
A facelift for your home Grumpy Remodeling 0 07-07-2004 07:43 PM
