So another question in regards to my attic vent fan. I am curious if you guys think I should have it hooked up and why. I have heard so many opinions but still curious. The fan kicks on at a particular temp and runs until below that temp.
What other venting do you have?
Is there soffit vents, gables, ridge?
What style roof is this?
It's always best to include your location in your profile. Just go to quick links to edit.
I am located in Virginia Beach VA. I do have the soffits but that is it. No other type of vents and the vent fan is only on one side of the roof.
I just hear a lot of people say that these fans just suck out heat or air when trying to keep the right temp in the house. Then I hear from others that they are good.
Uh, sucking out the hot air in your attic IS good. That's what the fan is for. And if you really have only soffit vents, you don't have any attic ventilation at all without it. Are you sure you don't have a ridge vent or gable vents? I have owned houses with no attic ventilation whatsoever (common in the old days) but never one with just soffit vents - there'd be no point to them.
Yes, it is. The fan is controlled by a thermostat, so unless the attic temperature exceeds its setpoint (maybe 110 degrees or so), the fan won't come on.
That aside, you should really consider additional venting. It isn't hard to install.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
