Anchoring Island Cabinets Into Tile Floor - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-05-2013, 08:25 AM   #1
Rewards Points: 1,062
Anchoring island cabinets into tile floor
People,
Hows the best way to anchor down some cabinets which will be an island into a ceramic tile floor? Tile is on concrete slab. Im thinking , since the base of each cabinet is not even exposed (the floor is about 3-4" above base) that only way is to drill a hole into inside cabinet, at base, toward the tile, then drill into tile, then screw in a long screw. Seems goofy. Ideas welcome.
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 04-05-2013, 08:35 AM   #2
Rewards Points: 1,426
Maybe you could use construction adhesive.
mikegp is offline   Reply With Quote
The Following User Says Thank You to mikegp For This Useful Post:
noquacks (04-05-2013)
Old 04-05-2013, 08:50 AM   #3
Rewards Points: 12,808
Trying to picture how the floor can be above the cabinet.
Got a picture of that cabinet?
Old 04-05-2013, 08:55 AM   #4
Rewards Points: 6
Screw some 2x4's flat side down to the floor to act as cleats. Then put the cabinets over the cleats then screw through the toe kick into the cleat.
Dan
djlandkpl is offline   Reply With Quote
The Following 3 Users Say Thank You to djlandkpl For This Useful Post:
Dave Sal (04-06-2013), joecaption (04-05-2013), oh'mike (04-06-2013)
Old 04-05-2013, 02:26 PM   #5
Huh?? floor above cabinet? Cmon, Joe, whats that??
Old 04-05-2013, 02:27 PM   #6
Geez, that just might be the best alternative! Thanks, man!
Old 04-05-2013, 05:00 PM   #7
" (the floor is about 3-4" above base) " You tell me.
Old 04-05-2013, 10:25 PM   #8
Lord of Slums
Rewards Points: 1,974
the floor of the cabinet itself, not the cabinet was recessed in the floor. Joe just reads these posts real careful like.
mj12 is offline   Reply With Quote
Boxed Tile Different than Sample on Floor greentrees Tiling, ceramics, marble 4 05-31-2012 08:03 PM
Should I remove tile floor after minor flood? dan1980 Flooring 5 05-24-2012 04:48 PM
Asbestos Removal, Porcelain Tile Installation jimbriam Flooring 15 01-30-2012 02:46 PM
Concrete floor prep for ceramic tile tpanc13 Flooring 39 06-22-2010 09:50 PM
Removing floor tile glue from a wood floor mrmordun Flooring 2 09-03-2008 10:41 PM
