Anchoring into retaining wall
We have old concrete retaining walls at our condo building that were cracked and looking pretty dilapidated so we had them refinished. The contractor put metal mesh over the walls and then put a skin coat of concrete over that.
I would like to install a couple hose brackets on the walls, but I am unsure of what type of anchors to use. Should I use tapcons? Sleeve anchors? I worry about the possibility of there being a hollow space between the old wall and the new finish, I don't want to drill and have it crack on me. Recommendations? |
Proby, no anchor expert here, so please accept this as brainstorming rather than advice, but...
my first though is that while I would normally be inclined to use a sleeve anchor, I think that I would lean toward a tapcon in this case, because since the cracks are now concealed, you won't know exactly where they are, and I think that a tapcon permits a better "feel" of what you are into than other types of anchors may. Secondly, is there a way to support the weight from the ground, or over top of the wall, i.e. a treated 2x4, for example, standing upright, tapconed to the wall, so that a significant portion of the weight is transferred directly to the slab or whatever, or a couple pieces of of aluminum flat stock bent to hook over the top of the wall, perhaps with a tapcon in each one to take out any wiggle at the brackets. Again, simply a couple of thoughts. |
Both tapcons and lead sleeves require a hole drilled prior to intalling either material. The lead anchor, in my opinion, would hold better then a tapcon, especially if what you're hanging is going to move. Ron. |
2 Attachment(s)
I know what a lead anchor is and a sleeve anchor as well, but I am not sure what a lead sleeve anchor is. I've attached images, the first one is what we call a lead anchor and the second is what we call a sleeve anchor. Different areas call things like this different things so it's hard to relate it over the internet. |
The lead anchor I was referring to is like a plastic anchor, only made of lead.
The skim coat isn't relevant as the anchor will be buried in the solid wall. The only issue you will have is the skim coats thickness as you don't want to rely on any part of it to hold the anchor. You might well move up a size to make sure you have enough ,"hold" in the wall. Ron |
Ron, I agree completely with what you said. My only point, and I see that I did not necessarily convey it clearly, is that regardless of how good of a job the mason did, I assume that the original cracks and dilapidation are no longer visible, and the issue that I see with any type of expansion type fastener is that they generally have a prescribed minimal distance from existing cracks, fractures, etc. Point being that when you tighten, and do not know where such deficiencies were, are you one turn, two turns, or X number of inch/pounds from the hole opening up. Again, no expert, but do have experience with similar anchors in larger, industrial applications. On the other hand, I am sure that tapcons are not without their own peculiarities, so if all things are equal, I will go back to my opening comment, and say that I too would be inclined to use an anchor as Ron described.
the advantage of the sleeve anchor ( aka Lok-Bolt, Dyna-Bolt) is you don't have to drill a giant hole to use it. you might try to just use screws and plastic anchors. they are cheap and if the block isn't too bad or is grout filled they might do the trick. if they don't hold you are literally out $1.00 and can try something else. if you drill into voids you could even use toggle bolts the best solution for a long lasting connection is to drill all the way through the wall and just use a long bolt, carriage bolt, or even threaded rod with a nut and washers on both sides. whatever you chose, try to get it in stainless steel if your budget allows |
You shouldn't have an issue with the 4" tapcons either. Ron |
| All times are GMT -4. The time now is 09:45 PM. |
