Altering Existing Door Jamb - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-18-2009, 08:56 AM   #1
Altering existing door jamb
I'd like to change my 1950's balcony door so it opens inward so that I can install a flywire door opening outward. The issue is that the door jamb isn't currently deep enough on the inside to house the door.
You can see from the photos that I think I could remove the centre strip (if it's not moulded) on either side and replace with a shallower one, but what about the top and the cement step at the bottom? Would I also need to replace the top section? Can I cut the door so it sits on top of the cement step?
Any advice on the best way to tackle this would be greatly appreciated.
JakeS is offline   Reply With Quote
Old 08-18-2009, 09:04 AM   #2
Sorry I think I have posted in wrong forum section and can't seem to move it. maybe a friendly moderator will
Old 08-18-2009, 09:09 AM   #3
Registered User
Termite's Avatar
No problem Jake, I moved ya over here.
Old 08-18-2009, 09:13 AM   #4
Registered User
Termite's Avatar
The biggest hurdle I see is the cement threshold. If the door were situated on it instead of against it, rainwater could very likely enter the structure and/or deteriorate the jamb despite your best weatherstripping efforts.
The top of the jamb looks odd, but I don't think that it would be too tough to remove and replace if you're a decent carpenter. The jamb stops on the side should come out with careful work with a nail bar.
Based on the threshold configuration alone I think I'd advise against this.
Old 08-18-2009, 09:41 AM   #5
Thanks for moving the thread and your quick reply.
Yeah the cement threshold could be a pain. The top of the jamb sits on top of the sides and some quad, do you think it might be hard to remove without destroying other parts?
I should have mentioned though, that the balcony is covered above and only open on one long side, so only really severe storms causing sideways rain could blow in there. Plus, if I have a flywire/security door on the outside that closes against the cement threshold, it should also help keep rain out. What do you think?
I don't think the look of flywire inside is acceptable and having this door open gives excellent cross ventilation.
Tags
door jamb frame
Replacement Aluminium Window - Reusing existing sill flashing? GrantJohnson Building & Construction 4 02-10-2010 11:27 AM
Adding receptacle on existing circuit schnitz411 Electrical 2 08-12-2009 06:15 PM
New Roof and Insulation over Existing Roof MitchellScott Roofing/Siding 1 05-03-2009 09:24 AM
Blending ceiling patch with existing sheet-rock (slight texture) gmhut Painting 3 07-29-2008 12:16 PM
