Airconditioner Fan Noise? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-11-2011, 11:35 AM   #1
airconditioner fan noise?
i have carrier central airconditioners (4) in my house. The fan motors on the outside with the compressor occasionally squeel and hang up - and the fan stops or won't start spinning. I can usually free it with a screw driver - and seems to run fine (for years).. I'm looking for a way to lubricate the fan motors. There are 4 holes above the fans that look like lubricating ports? Should/could I take the fan off and turn it upside down and spray lubricant "around" the shaft?
tomazz is offline   Reply With Quote
Old 01-11-2011, 11:56 AM   #2
Experienced
Jackofall1's Avatar
No I wouldn't do that, lubricant and electric motors really don't get along very well.
A few drops of 3 in 1 oil on the shaft may help, but what you are describing sounds like a bad bearing.
Lubrication points on electric motors are typically perpendicular to the shaft orientation and located very close to the ends of the motor.
Rattling Noise from Roof when windy drgillian Roofing/Siding 3 02-18-2011 10:05 AM
can you help me with this really odd noise? tuffluck Electrical 15 01-10-2011 06:35 PM
Frigidaire freezer noise (sounds like a compressor) onelove Appliances 3 10-09-2010 10:16 AM
Flat roof rafters noise mtrx Roofing/Siding 5 03-09-2010 11:16 PM
Noisy furnace (with recording of noise) Jeffrey HVAC 3 01-23-2010 02:17 PM
