Air Compressor Motor - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-25-2011, 06:50 AM   #1
jburd964's Avatar
Rewards Points: 166
Air compressor motor
I have another problem with compressor motor. After replacing compressor, now the motor doesn't have enough torque for the initial start. If I help it with first rotation it runs fine. What would cause this to happen?. The motor and compressor are both rated as 5HP. I'm already vest to deep into this thing to buy another. Somebody tell me some simple is the problem. I think it could be a bad actuator not putting out enough to carry initial surge.
Gun control isn't about guns, IT'S ABOUT CONTROL.
jburd964 is offline   Reply With Quote
Old 09-25-2011, 07:14 AM   #2
DIY staff
Rewards Points: 7,174
You don't have this thing on an extension cord do you?
Mine won't start unless plugged in to an outlet.
I have one the only likes synthetic oil.
Old 09-25-2011, 10:17 AM   #3
jburd964's Avatar
Rewards Points: 166
It is on a 10/3 wire/cord with plugs for welding machine that I put on both ends. It's this way only till I get it operating correctly then it's back into it's hole and hard wired. It was on same cord before I replaced compressor, and it worked fine.
Old 09-25-2011, 10:47 AM   #4
jschaben
Rewards Points: 502
Check the polarity of the start capacitor. If you got the wires backward it will have low start up torque, some will even try to run backwards.
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
Old 09-25-2011, 11:02 AM   #5
Remodeler
Rewards Points: 320
Is the compressor under load?
Your tank should have a check valve between the compressor and tank, this seals to hold pressure in the tank, it can sometimes stick open or fail.
You also have an unloader valve to bleed the pressure off of the compressor pump each time the compressor shuts off. Often this is a small valve on the side of the pressure switch.
Both of these work together to allow the motor to spin up before it comes under load.
iamrfixit is offline   Reply With Quote
Old 09-25-2011, 12:53 PM   #6
jburd964's Avatar
Rewards Points: 166
As for as polarity are you meaning flip the black and white?
Old 09-25-2011, 12:58 PM   #7
biggles's Avatar
could be the last cycle of pressure the motor is trying to start against that is in the head..vent the head and start the compressor or pressure off the tank....something like a refrig and waiting 2 minutes till the pressures balance out....
Old 09-25-2011, 01:00 PM   #8
jburd964's Avatar
Rewards Points: 166
The check valve is sticking open. When compressor reaches 2
145 psi it shuts down, then the little release valve on side of regulator bleeds it down to 85psi before shutting off. I went out last night and drained tank pressure to zero and it still didn't want to start. Is there anyway that pressure is not releasing from between regulator valve and compressor?
Old 09-26-2011, 06:19 AM   #9
Mold!! Let's kill it!
Rewards Points: 2,012
Try starting the motor without the belt to the compressor pump. If it's a bad start capacitor, it likely won't start even if it's not under load.
The Following User Says Thank You to Maintenance 6 For This Useful Post:
Thurman (09-26-2011)
Old 09-26-2011, 07:20 AM   #10
jburd964's Avatar
Rewards Points: 166
I took check valve out last night it was filthy for blow bye of old compressor, clean it and reinstalled. But in the dark damaged the tubing to regulator. I'm off today and will repair as soon as things open up. I'm believing that was the problem and will post as soon as I get results. I haven't ran without belt in place but am 99percent sure it would run.
Old 09-29-2011, 12:05 AM   #11
jburd964's Avatar
Rewards Points: 166
Ok, here's latest on compressor. I fixed the damaged 1/4" pressure regulator tubing, compressor still wouldn't start with out assistants. But there is improvement, compressor shuts off as it should without the 40# drop in pressure. I took bought capacitors off brought them to tool shop and ended up replacing both. Reinstalled and guess what? Still want start by it self €{'#€>{}
Talked to tool guy, he said remove electrical end of motor and inspect motor speed switch. I did, wasn't much other then needed clean and I cleaned contacts, reassembled it and zip knotta same thing. Removed motor took it bye his shop on way to work and he made a few adjustments to motor drive connector switch and wa la it runs fine. If all goes as planned will reinstall and tighten up a couple leaky fittings and this PIMA will be behind me for a long time.
I did stay at Holiday Inn Express last night.
