Air Compressor Flips Breaker - General DIY Discussions - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-06-2011, 07:19 PM   #16
It's a 240v 15amps twin v craftsman model 919.152811. There is a check valve, but how do you test it to see if its gone. Bad?
Dusty_cltr is offline   Reply With Quote
Old 12-06-2011, 07:42 PM   #17
I think its cheap enough to just replace. I think 12 but not sure
ralphsch is offline   Reply With Quote
Old 12-06-2011, 10:06 PM   #18
Rewards Points: 22
Granted, I was the one who brought up the check valve in the first place, and granted that it is possible that it too is bad, but if the compressor kicks off before it even has a chance to start compressing air, I do not believe that it is the primary problem, per my subsequent retraction of that suggestion. If it is kicking off before it builds air pressure in the tank, the check valve and other components are non-factors, so the problem is a lack of power, whether because of inadequate "juice" or the pump is seizing. On the other hand, I am not there, so perhaps it is building some pressure before it kicks off, in which case it could be the check valve. It is simply a spring loaded one way valve, which allows air to flow from the pump to the tank, but not from the tank back to the pump, and sometimes the problem is obvious enough if you remove it, perform a visual inspection, and check to see if the spring is doing its' job by pressing the disc in the proper direction.
Old 12-06-2011, 10:32 PM   #19
Rewards Points: 5,336
Just plug the compressor directly into a 20 amp circuit and eliminate it as an issue.
Ron
B. Franklin 1759
Old 12-06-2011, 10:46 PM   #20
Rewards Points: 22
Dusty, let's back up here. Ron asked you a while back if it is on a tandem breaker, but I don't see where you answered that question. If it's not, that is your problem; it is not connected properly,
Old 12-06-2011, 11:13 PM   #21
He didn't know what a tandem breaker was. I don't know if he's researched that yet.
I thought it was pertinent.
Ron
B. Franklin 1759
Old 12-06-2011, 11:46 PM   #22
Rewards Points: 22
And I agree 100%, but I naively assumed at some point that since he was still looking for a solution that he had confirmed that it was hooked up to run at 220, but then glanced back to see if maybe I had missed something relevant, saw that your question was still open, and now am wondering if it is hooked up to 110.
Old 12-07-2011, 11:18 AM   #23
It is on a tandem breaker. I'm going to try to move this to a new location with a larger power supply in the next day or two. Thanks for all the help, and I'll let you know what I find out! My electrical skills arent that great, so thanks for the patience!
Old 12-07-2011, 11:46 AM   #24
jschaben
Rewards Points: 502
This may be kinda dumb but the original post said "oil-less". Sounds like a pretty big compressor for an oil-less.
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 12:36 PM
Replacing and Moving a Fuse box with a breaker box nightrook Electrical 18 09-24-2009 08:49 PM
I can "double" the wires to each breaker in my breaker panel right? Piedmont Electrical 40 10-01-2008 12:18 PM
20 Amp Breaker tripping with GFCI panhandlion Electrical 7 12-12-2007 09:59 PM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 06:44 PM
