Air Bubbles Forming In New Tub Surround - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-12-2008, 11:54 AM   #1
Air bubbles forming in new tub surround
I recently installed an American Shower & Bath 5 piece tub surround over drywall, some of it painted, some of it new. I used 8 tubes of adhesive, spreading it with a 1/4 V trowel, using Liquid Nails Tub tub surround adhesive. I followed all directions. Initially the surround laid out flat and looked good, but now I see air bubbles are starting to form under the surround, 2-4 inches wide, breaking away from the adhesive, maybe 1/8" or higher.
Is there a way to fix this? What happened?
LBreaux is offline   Reply With Quote
Old 01-13-2008, 01:25 PM   #2
It may have needed bracing until the adhesive dried.
redline is offline   Reply With Quote
Old 01-13-2008, 04:14 PM   #3
Thanks for your response, redline. My post wasn't clear on the fact that it's a thin-wall tub surround, the kind that bonds directly over the wall surface. I did a little research (after posting here) on the Liquid Nails website and found out that the adhesive I used, Liquid Nails for Bath and Shower Surrounds, isn't recommended for thin-wall surrounds. Their adhesive display, however, was sitting next to the surrounds at Home Depot, and the associate indicated it was the kind I needed. After it started to cure, in a couple days, the thin-wall surround began to bulge out in spots with air bubbles underneath (not a pretty sight) and became brittle, as I found when I began to take it off. Some sort of adverse chemical reaction had taken place. One wall where I used another type of adhesive had no such problems.
So, anyone putting up a thin-wall surround, don't use Liquid Nails unless you want to risk doing the job over. I'll be heading back to HD tomorrow to hopefully get another surround for no cost and the correct adhesive this time.
Old 02-12-2008, 03:30 AM   #4
Unhappy
How did it go?
How did your talk with HD go? We had a similar thing happen (and they gave us the wrong tub too) but we figured they would never admit to it so we have just been living with it. Did you have any luck?
ChrisT is offline   Reply With Quote
Old 02-12-2008, 07:50 AM   #5
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Take some pictures of the display location (covertly), get the name of the HD person you originally spoke to also.
- Build Well -
Old 02-12-2008, 09:08 AM   #6
Home Remodeler
Rewards Points: 164
I installed one three weeks ago using the same glue you used, so far no problem. The directions tell you to install the panel and the pull it off for a couple of minutes to let the glue vapors dissipate, if you did not do that it may be the problem. The dap glue was recommended by the mfr of the surround.
mikey48 is offline   Reply With Quote
Old 02-12-2008, 09:59 AM   #7
I can't speak for any of the adhesives or items here, but I will say that most adhesive manufacturer's will state that you may need to allow time for the adhesive to set up and become "tacky" prior to the actual placement of the materials.
- Build Well -
Fireplace surround tiling Ducowti General DIY Discussions 8 10-28-2008 09:16 AM
Tile Surround on Tub leted_82 Building & Construction 2 09-12-2007 08:34 AM
What to do with area about tub surround? geowoman Remodeling 7 05-05-2007 01:56 PM
wiring for surround sound? starnz General DIY Discussions 2 12-20-2006 08:13 PM
bubbles farrington135 Painting 4 10-14-2006 06:38 PM
