Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 01-30-2012, 02:50 PM   #1
After sandblasting: Is sand residue around exterior house dangerous?
We recently had our house exterior sandblasted to prep for new stucco. They used "silver sand" (silica?) workers cleaned up pretty good all-around, but left a few inches of sand residue in the dirt beds around the house. Is this sand media still dangerous in that form (lying around in the dirt?) ... Or only while the sandblasting process is going on?
sings2strings is offline   Reply With Quote
Old 01-30-2012, 02:52 PM   #2
Super Moderator
That's harmless--ocean sand---turn it into the garden --should not hurt anything--
Old 01-30-2012, 02:54 PM   #3
MarginallyQualified
The danger, or risk, comes from whatever it was that got blasted off.
The Following User Says Thank You to TarheelTerp For This Useful Post:
oh'mike (01-30-2012)
Old 01-30-2012, 02:56 PM   #4
joed's Avatar
The sand is harmless. Like stated above the risk is in what got blasted off. For example if was lead paint then you could have lead contamination in you ground now.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 01-30-2012, 03:00 PM   #5
The sand is harmless or is it.
www.buildsafe.org/hazalerts/KFsilica.pdf</SPAN>
Hardway is offline   Reply With Quote
Old 01-30-2012, 03:07 PM   #6
concretemasonry's Avatar
The sand can be mixed with peat or heavy top soil and pulverized to make a great planting soil for flowers and vegetable gardens.
Dick
concretemasonry is offline   Reply With Quote
Old 01-30-2012, 03:27 PM   #7
I read the previous poster's link:
I'm confused... why do they sell the sand for sandblasting if it is so harmful? It's nearly impossible to clean up!
Old 01-30-2012, 03:45 PM   #8
Go to www.frbagging.net/ under commercial sands click sands, then scroll down and click MSDS.
There is a 1-800 number you can call and find out what you should do, or if you can just allow the sand to mix in with the earth or not.
Writer’s information is for discussion purpose only and should be confirmed by an independent source.
Old 01-30-2012, 03:58 PM   #9
The problem with silica sand is the fine resperable portions that can be inhaled over long periods of time. That is the reason so many materials associated with fines that are created during some sort of process. Above all, avoid broken glass since it is chemically the same as silica sand.
From a practical standpoint, any scattered sand blasting debris from silica sand would be blown away or washed into the soil and not be resperable or dangerous. This is based on the "dillution is the solution to pollution" philosophy that is employed in the treatment of sewerage dumped into rivers.
Dick
Old 01-30-2012, 04:05 PM   #10
Sandblasting sand is screened so the fines are not shipped in the bag. Yes, it does break up a bit in use, but this is chiefly a risk for the sandblasters. Theoretically, if you leave clouds of fines (fine sand) laying around to blow, they could be a problem, but realistically they wash away pretty quickly.
Just turn it into the soil and you'll be fine. It occurs naturally, and if you are really worried stay away from beaches. They're full of it.
I used to work for a major producer of the stuff both testing and hauling it by barge.
ptarmigan61 is offline   Reply With Quote
Old 01-30-2012, 06:26 PM   #11
joed's Avatar
never mind
Old 01-30-2012, 08:27 PM   #12
Wire Chewer
Red Squirrel's Avatar
Try to get rid of the most you can, like if there's sections where it's accumulated and can be scooped up, but the rest can probably just be mixed in with the ground as suggested.
Old 01-31-2012, 10:44 AM   #13
Thanks for the replies. I think I will remove the bulk of it (after watering it down) and then incorporate the rest in the soil. Need to get it done before the Santa Ana winds come stirring it all up!
Tags
sand, sandblast, sandblasted, sandblasting, silica sand
After sandblasting: Is sand residue around home dangerous? sings2strings General Discussion 1 01-31-2012 08:03 AM
Has my electrician done a dangerous wiring job? Homervanderjazz Electrical 25 01-20-2012 10:48 AM
Is this a dangerous practice? WingNut Electrical 29 08-26-2009 01:38 PM
