Advice On Tin Ceiling Install - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-21-2008, 07:27 PM   #1
Advice on tin ceiling install
Hello,
We are wanting to put tin ceilings in a bedroom. We just finished laminate floor install in a 2,000 sq. ft. area, so we are capable folks. We would like some guidance if you have experience with this work.
1. Where did you buy your materials? We live in a small town and no one local has anything.
2. Any general or specific tips?
Thanks,
Jim
Jim1970 is offline   Reply With Quote
Old 07-22-2008, 08:00 AM   #2
47_47's Avatar
Rewards Points: 62
I am fortunate that I can get 90% of my materials locally. Freight in is a big expense. Do you have a local lumber yard? Most lumber yards order from different vendors and get their materials trucked in and they can sometimes aggregate your material with their shipments. For me, a 30-40 mile one way drive is common. If we need to go further (90+), we make a day of it. Use the web and research the products you want to use.
From the little research I've done, you should screw 1/2" plywood through the existing drywall into the existing ceiling joists for nailers. If you have overhead fixtures, lower the boxes or use box extenders. For a tin ceiling try Outwater Plastics, but they can be pricey.
Good luck.
47_47 is offline   Reply With Quote
Old 07-22-2008, 08:04 AM   #3
Registered User
Termite's Avatar
The plywood is a must. The nails won't grab very well in plaster or sheetrock. I would think that you could use 1/4" ply, but I haven't ever tried doing a tin ceiling myself.
Old 07-22-2008, 10:26 AM   #4
47_47's Avatar
Rewards Points: 62
1/4" should be enough to to hold a ring nail, but I recommend 1/2" to minimize the bounce when nailing.
Old 07-22-2008, 12:15 PM   #5
Hello,
Thanks for the feedback.
Right now we have exposed studs and insulation, along with plumbing. I figured to use 1/4" plywood and basically frame the ceiling using the plywood. From there, the project seems pretty simple.
Thanks again,
Jim
Old 07-22-2008, 04:10 PM   #6
Registered User
Termite's Avatar
Originally Posted by Jim1970 View Post
Hello,
Thanks again,
Jim
If there's no rock currently hanging on the ceiling joists I'd definately use 1/2" plywood.
Old 07-22-2008, 06:28 PM   #7
Hello,
1/2" instead of 1/4"? Unfinished is fine since it will be hidden, correct?
Jim
Old 07-22-2008, 07:14 PM   #8
Fixer-'til-broker
DIYtestdummy's Avatar
Rewards Points: 262
5/8" will work. Gently swing the hammer, or if you have an air nailer set the pressure low to avoid crushing the tin.
"Aw! Why does everything that only happens to stupid people happens to me?" - Homer J. Simpson
DIYtestdummy is offline   Reply With Quote
Old 07-22-2008, 08:46 PM   #9
Registered User
Termite's Avatar
Hello,
Jim
Jim,
Yes, since there's not the added weight of the sheetrock in this case, additional plywood weight won't be an issue. Therefore, I'd suggest 1/2" plywood as a substrate. It will be more rigid than 1/4" would be, and would be easier to hammer the tiny tile nails on, as a previous poster pointed out.
The previous post mentioned an air nailer for applying the tin ceiling. Although a nailer would aid in installation of the plywood, I would absolutely advise against using one for the tin tiles themselves. Air-driven brads and trim nails lack sufficent head to properly secure the tiles, and a framing nailer is just overkill. You'll want to use a light hammer and nails that match the tiles. You could use pan head screws in the same color to simplify installation, although I think they'd be noticeable.
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 10:05 AM
Can I install 12x12 porcelain tile on a shower wall or ceiling? dezigner80 Remodeling 6 09-15-2009 12:05 PM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
Anyone install a tin/copper style ceiling? flashme18 Remodeling 7 07-19-2009 07:56 AM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 08:23 PM
