Advice On Organizing A Workshop - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-22-2009, 04:59 PM   #1
Rewards Points: 150
Question
Advice On Organizing a Workshop
We just finished constructing an 8'X10' workshop from a kit. It's on 24" centers and the studs were 2X3s. I plan on insulating the ceiling but not doing much more to the walls. I want to build a workbench, perhaps attaching a 2X4 cleat to the studs, creating legs and putting some sort of top on it and a shelf below for some storage. Right now all I have in there is a miter saw on a rolling work table but not sure how/where to start on organization for hand and power tools, attachments, fasteners like nails/screws/etc. Is peg board a good option, or will it eventually give way. What about attaching some plywood or MDF to the wall[s] and using hooks and/or shelves? I'd appreciate any suggestions and advice.
shapeshifter is offline   Reply With Quote
Old 11-22-2009, 06:40 PM   #2
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Shape, Congrats on the new shop. You are probably in the minority in having a dedicated space as most us in the DIY world use a corner of the basement or garage. You are also lucky living in S Texas where you can work year round without heat.
I would start out with a standalone bench rather than building one against the wall, same for not building in storage or pegboards, until you have used it for while and know better how things will work for you.
Provide enough open floor space for work in progress. Make room for a stool or chair or stool so you can sit in front of the bench and change a lamp plug. How are you fixed for lighting and receptacles? How about a charging station for batteries?
I have a couple of portable pedestal stands one for a vise and the other for a grinder that can be pushed against the wall of my garage or moved outside.
more info:
http://woodworking.about.com/od/shop...And_Layout.htm
Disclaimer
& Stay Safe
.....Bob Lavery
Old 11-22-2009, 08:04 PM   #3
Rewards Points: 150
Pali thank you for the insight. Actually, I got my workshop kind of by default, now my hubby knows I won't be moving into a corner of HIS garage LOL. He will be adding electrical for lighting and receptacles this week. I believe I may construct a work bench and add casters like the one on my miter saw table. On that, we used 4" multi-directional casters with a locking feature. As far as making room for all my stuff, I guess I'll move an old shelving unit in temporarily. One other thought, I have tons of different sized nails, bolts and screws left over from various projects. What do you recommend for a sorting/storage system.
Old 11-22-2009, 11:37 PM   #4
Rewards Points: 372
I like the cardboard parts boxes available at NAPA, about $1.00 each. Grainger, Northern Tool, lots of places have plastic parts boxes in color.
fireguy is offline   Reply With Quote
Old 11-23-2009, 11:26 AM   #5
Rewards Points: 150
Small carboard boxes look like a real good option. I could label each box with the type and size fastener, or even make computer labels with a picture of the item. Thanks for the suggestion.
Old 11-23-2009, 08:48 PM   #6
Rewards Points: 1,016
I don't worry so much about sorting or catagorizing odds and ends. I like shallow metal pans for misc. bolts, nuts, etc. You can readily sift through and find what you need.
Old 11-24-2009, 06:52 AM   #7
Mold!! Let's kill it!
Rewards Points: 2,012
One pound coffee cans, duct tape and permanent markers make the most indestructable parts bins I've ever used. If you set your workbench on caster, make provisions to bolt it fast to the wall when you need to. Beats having it wander around the shop while you are trying to work. Shelf tracks like KV-80 http://www.knapeandvogt.com/Regular-...roducts.18.220 with a variety of brackets let you move shelving to accomodate different size materials.
Old 11-24-2009, 10:07 AM   #8
Tool Geek
PaliBob's Avatar
Avoid buying any of those bench top plastic drawer units for misc stuff.
They look nice, but NG for dissimilar hardware.
The solution I like plastic compartment boxes where everything is visible
http://www.casesandmore.com/Flambeau...0-FLB1054.html
Remember, it is not worth saving if you donít know where to find it. Most folks save too much stuff. (including me)
Disclaimer
& Stay Safe
.....Bob Lavery
New 60A or 70A service to expanded workshop CozumelDiver Electrical 5 03-24-2008 11:26 PM
Electrical Advice Caution!!! Mike Swearingen Electrical 12 03-05-2008 11:51 AM
I need advice on a flat roof Krissy Roofing/Siding 10 12-27-2007 01:55 PM
Workshop Panel Grounding/Bonding IdahoBob Electrical 3 01-29-2007 11:13 PM
