Adjusting Sliding Glass Doors - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-26-2010, 07:24 PM   #1
adjusting sliding glass doors
I have a sliding glass door that door that does not line up with the stricker. How can I adjust it.
bob grube is offline   Reply With Quote
Old 01-26-2010, 09:37 PM   #2
Custom Cabinet Maker
If Andersen pop the covers on the bottom and adjust the rollers hidden inside
skymaster is offline   Reply With Quote
Old 01-27-2010, 06:50 AM   #3
The bottom rollers on most sliding doors are adjustable, so you can tilt the door as needed to fit flat on latch side. There are holes on the inside side of the doors(covered with plastic caps) or at the ends at the bottom for acces to the adjustments. Location depends on the manufacturer.
Old 01-27-2010, 08:42 AM   #4
I tried that and it doesn't seem to move much. It has two holes and you have to turn one before the other will turn. does the weight have to be off the door before it can be adjusted?
Old 01-27-2010, 08:48 AM   #5
Rewards Points: 5,336
Do you know who made the door? Is it wood? Metal? How old?
If the adjustment doesn't work, it might be an old door. You might try shooting a silicone spray into the holes and let it soak in for a while. The Andersens and Pellas are easily adjusted just sitting on the track.
Ron
Old 01-27-2010, 02:41 PM   #6
Thanks for your quick reply. It is a Anderson metal door. I can only get about 3 turns and then I here a click. I know the floor is not level but it was working fine until I tried adjusting it to glide more easily.
Old 01-27-2010, 03:24 PM   #7
There should be small wheels inside that could need replacing. Try to remove the slider and take a look.
antlerdancer is offline   Reply With Quote
Old 01-27-2010, 05:10 PM   #8
If you're speaking about an "Andersen" door, they do not make metal doors.
As antler said, remove the door and look at the under side for the issue. If after you've tried lubricating it, and it still doesn't adjust. Parts will probably be available, but unless you're in a large populated area, you'll have to find it online.
There's a possibility it is at it's limit and the actual issue is that the jamb isn't plumb.
Ron
Old 01-28-2010, 11:25 AM   #9
Ron, sprayed them with silicone and they adjusted easily. Thanks again.
Old 01-28-2010, 11:32 AM   #10
You're welcome.
Ron
8' Glass Sliding Doors dankreboot General DIY Discussions 6 07-10-2008 09:11 AM
Trouble Removing Sliding Glass Doors Drewimus Carpentry 1 11-05-2006 01:43 AM
Sliding Glass Doors Drewimus General DIY Discussions 2 10-02-2006 10:06 PM
