Adhesive For Granite To Cast Iron Table Stand - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-28-2010, 06:33 PM   #1
Adhesive for granite to cast iron table stand
I have a 21x32x1 inch kitchen sink cut-out from our marble countertop that will make a nice table for our porch. We have a left-over base that we want to attach it to and it looks to be a painted cast iron material. The thickness of the marble makes it a tad high but if necessary I could attach a thin piece of masonite to it, if that is of any help. I see a product Liquid Nails Marble that may work but it does not state it would work with metal surfaces. Any suggestions on whether this is my best bet?
howard611 is offline   Reply With Quote
Old 03-28-2010, 06:40 PM   #2
DIY staff
Rewards Points: 7,174
Look under your new counter and look at the threaded studs that hold the sink--Would that work?
Epoxy is the glue that is keeping the studs in the drilled holes.
If you don't need studs to keep the top and base together--epoxy will stick to steel--make sure the steel is flawlessly clean.--Mike--
Old 03-28-2010, 07:41 PM   #3
your suggestion did not address my project
Mike thanks for your reply but I am not dealing with a granite counter.
I am making a table with a left-over piece. nevertheless, if epoxy is the right glue to make my table, thanks for the advice.
The Following User Says Thank You to howard611 For This Useful Post:
oh'mike (03-28-2010)
Tags
adhesive , cast iron , marble , metal
pvc to cast iron hub using fernco-can't get it! What have I done Plumbing 10 01-22-2014 07:55 PM
Main House Drain/Through Wall Cast Iron Pipe Docfletcher Plumbing 3 03-02-2010 07:41 PM
Cast Iron Pipe ehv8trix Plumbing 4 11-25-2009 06:49 PM
working with cast iron ericadami Plumbing 9 11-30-2008 12:45 PM
Cast iron and rusty pipe question snowens Plumbing 2 07-27-2008 10:07 AM
