Additional Fan In Closet - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 05-25-2013, 07:46 PM   #1
Question
Additional fan in closet
So, this may be a weird and multi-part question, so I didn't know where to post it exactly. Hopefully you can bear with me.
I live in a 2-story loft condo unit with concrete floors and ceilings. I have a closet and a bathroom on the first floor along the inner (hallway) part of the condo, and the bathroom fan has an existing fan vent that goes up the wall and out the opposite side of the unit. The vent pipe actually meets up with the upstairs bathroom's vent (so air from both vents can exhaust through the same pipe for most of the journey)
I recently got cats, so the litter box lives in the closet now, and often dry my hockey stuff in the same closet so I was thinking about adding a fan into the closet and joining it to the bathroom fan on the other side of the wall. Now, here's where my question gets interesting (as if it wasn't already):
My closet does not L-bend under the stairs; it's walled off, so I'm losing some storage space under that way. Mi initial thought was to drop that wall, move the two metal studs, and reroute the electrical conduit that's waist high up and over the top, install the vent fan, and be done.
Option 2 if it's not worth the extra space for the cost is to just add in a bathroom vent fan in the closet and not touch the closet layout.
Option 3 is to just install a passive vent between the closet and bathroom (just a duct with grates on each side) and allow the closet smells to passively get pulled into the bathroom when the fan is on.
Thoughts on any of these solutions?
Tankeray is offline   Reply With Quote
Old 05-25-2013, 07:51 PM   #2
Plumber
Get rid of the cat and get a dog.
DidIDoThat is offline   Reply With Quote
Old 05-26-2013, 08:31 AM   #3
PoleCat's Avatar
Rewards Points: 1,646
The bad thing about combining the fans into one exhaust pipe is you will get roughly equal discharge through the other fan(s) as at the intended point of exit. If it is feasable I would run three intakes into one fan and one exhaust. Then use three way switches or a timer to operate the fan.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 05-27-2013, 12:17 PM   #4
So would you say it would be better to make a vent opening in the closet, hook it up with the downstairs bathroom pipe, and put the fan in after where the two pipes meet? I would be fine with one closet and one bathroom switch controlling the same fan.
Also, I have two cats, so I'm worried that if I take a vote to expel them, they'll outnumber me.
Old 05-27-2013, 12:34 PM   #5
Rewards Points: 2,516
Why not put the litter box under the stairs?
hammerlane is offline   Reply With Quote
Old 05-27-2013, 02:22 PM   #6
Can't for two reasons right now:
1) There's no access to that area right now (it's walled in completely) and
2) the access point is my bottom stair, stairs go up as you walk to the left.
So my access point would be on the other wall, litter box and storage back under the stairs where you have it.
A little extra storage would be nice, and that way I can put the fan in the back of the closet if I open it up, but may end up costing $1000's just for 20 sq feet of extra storage that isn't even the full height
Old 05-27-2013, 06:20 PM   #7
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,884
If the dog is like most dogs I know, he/she will offer to clean the litter box for free.
Old 05-27-2013, 11:45 PM   #8
Registered User
Rewards Points: 5,216
It sounds as if the two studs supported the drywall you removed... be sure to cover the bottom of the stair framing (if wood) with drywall to be code-compliant for your H.O.Insurance carrier; http://publicecodes.cyberregs.com/ic...?bu2=undefined
Gary
Old 05-28-2013, 06:37 AM   #9
PoleCat's Avatar
Cat's do not respect a democracy. We have twelve and the political system observed is anarchy.
Your staircase appears to be on an exterior wall. It will cost nothing to remove the wall blocking the area under the staircase. The bathroom exhaust fan appears to be a wall mounted unit that will be exposed in the area under the stairs. It would be rather easy to pipe two fans seperately out the wall. Or you could use a single fan to service both areas.
Old 05-30-2013, 01:04 PM   #10
Rewards Points: 590
This is not a problem with a properly installed fan. There is a check flap in there. Otherwise, wind could also blow into the house from the outside.
operagost is offline   Reply With Quote
Old 05-30-2013, 03:18 PM   #11
Bill Kearney
Rewards Points: 1,174
Ugh, litter boxes in the closet just makes everything else in that closet stink. That and you need to leave the closet door open all the time.
What's laid out on the bathroom wall that faces the empty area under the stairs? Where's the plumbing and fixtures? Might there be a clever way to put a litter box 'room' in there with access from the bath? At least then the stink would be confined to a room that's already designed for that.
Otherwise I'd lean toward some of the more clever ways to disguise a litter box as 'furniture' and put it out elsewhere in the condo.
wkearney99 is offline   Reply With Quote
Old 06-04-2013, 06:05 PM   #12
Rewards Points: 131
Buy a cheap hollow core door for $19 and put a cat door in the bottom. Replace with a new one when you move out. I seen it done in apartments all of the time. As for the smell, that's part of the joy of owning cats (which I don't).
HitLines is offline   Reply With Quote
Tags
bathroom fan
Removing existing closet gnomonklater Building & Construction 4 12-02-2011 01:14 AM
Framing a new header for closet opening jmai14 Carpentry 6 07-09-2011 03:20 PM
Laundry closet decision LClark Remodeling 2 06-26-2011 07:19 AM
Hardwood closet threshold question DIY-Renovator Flooring 1 07-27-2008 05:42 AM
Musty smell from closet after leak Musty General DIY Discussions 2 09-10-2007 09:36 PM
