Adding Wall Insulation Inside Or Out? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-26-2009, 11:25 AM   #1
adding wall insulation inside or out?
My mobile home has R7 paper backed yellow fiberglass insulation against plywood , exterior paper then new siding, Inside there is just paneling against it and I know the studs are 2x3 but not sure how far apart because we had the wall apart before but men said to leave it alone.
Is it easier take the paneling off put new R14 and vapor barrier from the inside or should I take the siding off and put something on the outside? The front half of the mobiel has an additon and drywalled so I am going to leave it but the narrow back half is cold. Any suggestions beside going to Florida?
jg
jgreaves is offline   Reply With Quote
Old 09-26-2009, 06:16 PM   #2
Retired from the grind
gregzoll's Avatar
Rewards Points: 5,882
Do it from the inside. Plus side is, you can update the wiring & install CATV, Ethernet & Telco jacks in the wall where they should be.
gregzoll is online now   Reply With Quote
Insulation in an interior wall Avramel Building & Construction 1 03-10-2009 06:22 PM
Insulation in back of the knee wall Vermont1 Roofing/Siding 1 03-09-2009 06:03 PM
adding a load-bearing wall jpsmith Building & Construction 8 03-04-2009 08:19 AM
Adding a partition wall to a room with hardwood flooring Badfish740 Remodeling 4 12-29-2008 08:54 AM
