Adding Insulation To Kneewall - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-03-2010, 09:22 PM   #1
Rewards Points: 77
Unhappy
Adding Insulation to Kneewall
Hi,
I am in the process of adding insulation to my knee-wall's in a 1952, war time, storey and a half home. There is existing insulation (fibreglass batts R7) on the knee-wall which I want to cover with an R-10 ridged board. I will then blow in insulation on the floor of the attic space to finish this off.
My questions are:
Am I doing the right thing?
Do I need to worry about vapour barrier?
Where should the ridged board start/finish on the wall?
Can I use Tuck tape to seal the ridged board or should I use a foam spray?
Does anyone have any pointers/ideas to help me along?
All responses are welcome. Thanks Shorteared
shorteared is offline   Reply With Quote
Old 10-04-2010, 08:48 AM   #2
Rewards Points: 6,652
The batts need to breathe. I would just upgrade them to R-15, and forgive the rigid foam board.
The Following User Says Thank You to gregzoll For This Useful Post:
shorteared (10-04-2010)
Old 10-04-2010, 04:24 PM   #3
Registered User
Rewards Points: 4,924
The baffles at the soffit protect the insulation from wind-washing, the foam board extends up to the baffles at the knee wall to protect the sloped cavity insulation from w.w. there. If no blocking under the knee wall, extend the board into the joist bays to stop air there: http://www.buildingscience.com/docum...archterm=insul
http://www.homeenergy.org/archive/he...95/950309.html
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
Old 10-04-2010, 07:41 PM   #4
Rewards Points: 77
Thank you GBR in WA,
The website you provided (http://www.homeenergy.org/archive/he...95/950309.html) helped out a lot in understanding junctions, Now that my head is wrapped around this it is time to install the insulation. I appreciate your time and efforts. Shorteared
The Following User Says Thank You to shorteared For This Useful Post:
Gary in WA (10-05-2010)
Tags
adding , insulating , knee wall
Adding insulation and storage to Cape Cod Side Attic turin39789 General DIY Discussions 5 11-08-2010 11:50 AM
Adding Attic Insulation barneyrubble Building & Construction 2 08-23-2010 02:50 PM
adding attic insulation to existing insulation strouddljs General DIY Discussions 4 11-09-2009 06:06 PM
Adding attic insulation pomelo Building & Construction 3 10-22-2009 06:19 PM
Adding insulation to only a portion of an attic? curls00 Building & Construction 22 10-27-2008 10:41 AM
